Whenever I try to build the model using STM32Cube.AI gives this error
*For C++ library or Arduino it’s work fine and builds the model with no error
*I use STM32Cube.AI in other project and work fine!
Hi @RashadShubita Unfortunately there are models where Cube.AI will just crash. I guess you saw Build C++ Library with STM32CubeIDE already, which works.
Hi @janjongboom yes I saw it and it’s working fine, even I love the Cube.AI since I don’t need to add a punch of includes for C and C++
and it’s more optimized I think. so it would be nice if you and microelectronics could solve these bugs.
And thanks for your answer
Have a good day!
If you enable EON you should have models that are at least as small as in Cube.AI
Okay, thanks I already leave it enabled!
