Jetson Nano i2c sensor
I have set up edge impulse like normal on Jetson Nano 4gb, and have got it set up with a camera collecting data to a project, I am now using a i2c sensor(Grove 4 channel multi gas sensor). I wrote a python script, to read the data, and confirmed the Jetson is reading the data, and displays it in the terimial. But when I try to run data-forwarder, even after disabling the camera and microphone, it goes into a loop of not finding any devices over serial port. And I cant figure out how to get it to read the sensor data, and not get stuck in this loop
when trying to train the model
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
The data to show up in edge impulse and be able to add the training data
get stuck at cant find deive over serial port
Always
  • Platform: [Jetson Nano]
  • Build Environment Details: [Jetpack 4.6.4]
Hi @bgold2050,
Are you running edge impulse cli tools on the Jetson Nano? or on another device (e.g. host PC)?
In most cases when using Linux targets with supported sensors, edge-impulse-linux is what you want. edge-impulse-linux is then expected to run on the target (in your case Jetson Nano).
It sounds like you might be working with a custom sensor and in that case edge-impuls-data-fowarder might be what you want (if edge-impulse-linux doesn’t recognize the sensor).
The edge-impulse-data-forwarder is intended to run on a host (e.g. PC) with network connection, which interfaces the target (Jetson Nano in your case) via a serial port. The target outputs the data to the host pc which forwards it to the Edge Impulse via the edge-impulse-data-forwarder for more information see our Data forwarder docs.
Let me know if that helps and clarify the tooling and it’s usage.
// Raul James
