Error: Cannot find module ‘C:\Users\AMAZON\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\daemon.js’
←[90m at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)←[39m
←[90m at Function.Module._load (internal/modules/cjs/loader.js:746:27)←[39m
←[90m at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)←[39m
←[90m at internal/main/run_main_module.js:17:47←[39m {
code: ←[32m’MODULE_NOT_FOUND’←[39m,
requireStack: []
C:\Users\AMAZON>
All other steps including Updating the firmware, installing edge impulse , installing arduino cli have been success fly completed. I am using a window 10 OS
For a quick check just open your Command Prompt and type edge-impulse-daemon and if that doesn’t shoot any errors then you are good to experiment with the platform.
C:\Users\AMAZON>npm install -g edge-impulse-cli
npm ERR! code EPERM
npm ERR! syscall mkdir
npm ERR! path C:\Users\AMAZON’~.npm-global’\node_modules.edge-impulse-cli-JXOThjQB
npm ERR! errno -4048
npm ERR! Error: EPERM: operation not permitted, mkdir ‘C:\Users\AMAZON’~.npm-global’\node_modules.edge-impulse-cli-JXOThjQB’
npm ERR! [Error: EPERM: operation not permitted, mkdir ‘C:\Users\AMAZON’~.npm-global’\node_modules.edge-impulse-cli-JXOThjQB’] {
npm ERR! errno: -4048,
npm ERR! code: ‘EPERM’,
npm ERR! syscall: ‘mkdir’,
npm ERR! path: “C:\Users\AMAZON\’~\.npm-global’\node_modules\.edge-impulse-cli-JXOThjQB”
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It’s possible that the file was already in use (by a text editor or antivirus),
npm ERR! or that you lack permissions to access it.
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR! C:\Users\AMAZON\AppData\Local\npm-cache_logs\2021-07-27T05_20_59_743Z-debug.log
