Hi
When I run edge-impulse-data-forwarder.cmd I get the following error.
C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\bindings\bindings.js:135
throw err;
Error: Could not locate the bindings file. Tried:
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\Debug\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\Release\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\out\Debug\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\Debug\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\out\Release\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\Release\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\default\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\compiled\12.16.3\win32\x64\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\addon-build\release\install-root\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\addon-build\debug\install-root\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\addon-build\default\install-root\bindings.node
→ C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\lib\binding\node-v72-win32-x64\bindings.node
at bindings (C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\bindings\bindings.js:126:9)
at Object.<anonymous> (C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\lib\win32.js:1:36)
at Module._compile (internal/modules/cjs/loader.js:1133:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
at Module.load (internal/modules/cjs/loader.js:977:32)
at Function.Module._load (internal/modules/cjs/loader.js:877:14)
at Module.require (internal/modules/cjs/loader.js:1019:19)
at require (internal/modules/cjs/helpers.js:77:18)
at Object.<anonymous> (C:\Users\paul\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\lib\index.js:6:22)
at Module._compile (internal/modules/cjs/loader.js:1133:30) {
tries: [
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\build\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\build\\Debug\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\build\\Release\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\out\\Debug\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\Debug\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\out\\Release\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\Release\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\build\\default\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\compiled\\12.16.3\\win32\\x64\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\addon-build\\release\\install-root\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\addon-build\\debug\\install-root\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\addon-build\\default\\install-root\\bindings.node',
'C:\\Users\\paul\\AppData\\Roaming\\npm\\node_modules\\edge-impulse-cli\\node_modules\\@serialport\\bindings\\lib\\binding\\node-v72-win32-x64\\bindings.node'
Please advise.
I am using windows 10 with
node.exe --version v12.16.3
