When I follow the Installation - Windows instructions to install the Edge Impulse CLI, I get the following error when I run the command “npm install -g edge-impulse-cli --force”
npm error path C:\Users\andrcoll\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
Running the command “npm install -g edge-impulse-cli --force”
- Installed Python 3.11.9
- Installed Node 24.2.0
a. Installed the Windows Additional Tools for Native Modules - Tried to run the command “npm install -g edge-impulse-cli --force”
a. Results in error and the CLI not getting installed!
The Edge Impulse CLI properly installs
I recieve an error as stated above
Always
| Device Specifications | |
| Processor | Snapdragon(R) X Elite - X1E80100 - Qualcomm(R) Oryon™ CPU 3.42 GHz |
| Installed RAM | 32.0 GB (31.6 GB usable) |
| System type | 64-bit operating system, ARM-based processor |
npm error code 1
npm error command failed
npm error command C:\windows\system32\cmd.exe /d /s /c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm error gyp info it worked if it ends with ok
npm error gyp info using node-gyp@11.2.0
npm error gyp info using node@24.2.0 | win32 | x64
npm error gyp info find Python using Python version 3.11.9 found at “C:\Users\andrcoll\AppData\Local\Programs\Python\Python311-arm64\python.exe”
npm error gyp http GET https:// nodejs. org/download/release/v24.2.0/node-v24.2.0-headers.tar.gz
npm error gyp http fetch GET https:// nodejs. org/download/release/v24.2.0/node-v24.2.0-headers.tar.gz attempt 1 failed with SELF_SIGNED_CERT_IN_CHAIN
npm error gyp WARN install got an error, rolling back install
npm error gyp ERR! configure error
npm error gyp ERR! stack FetchError: request to https:// nodejs. org/download/release/v24.2.0/node-v24.2.0-headers.tar.gz failed, reason: self-signed certificate in certificate chain
npm error gyp ERR! stack at ClientRequest. (C:\Program Files\nodejs\node_modules\npm\node_modules\minipass-fetch\lib\index.js:130:14)
npm error gyp ERR! stack at ClientRequest.emit (node:events:507:28)
npm error gyp ERR! stack at emitErrorEvent (node:_http_client:104:11)
npm error gyp ERR! stack at _destroy (node:_http_client:898:9)
npm error gyp ERR! stack at onSocketNT (node:_http_client:918:5)
npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:91:21)
npm error gyp ERR! System Windows_NT 10.0.26100
npm error gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
npm error gyp ERR! cwd C:\Users\andrcoll\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
npm error gyp ERR! node -v v24.2.0
npm error gyp ERR! node-gyp -v v11.2.0
npm error gyp ERR! not ok
Note: I added spaces in the URLs above to be under the new user 2 link rule
I have tried the following:
- Re-install the tools for native modules myself using the command “choco install python visualstudio2022-workload-vctools -y” from these these docs
- Upgrading to Python 3.13.5
- Downgrading to Node 20.19.2
- As well as installing a ARM64 and 64-bit versions of Node
- Following this other forum post
- Manually installing @serialport/bindings with “npm install @serialport/bindings”
- This properly installs version 10.0.1 but installing Edge Impulse CLI results in an error
- When I manually install @serialport/bindings@8.0.8 I receive the same error as I do when I install edge-impulse-cli
- This leads me to believe @serialport/bindings is part of the error
