I am implementing my custom preprocessing block and I came across the rich implementations inside “edge-impulse-sdk/dsp”. Sadly, when I try to #include "edge-impulse-sdk/dsp/spectral/processing.hpp" inside my own preprocessing.hpp file there are plenty of linker errors, relating to multiple definitions. I have tried similar #includes but no luck.
Here is the output from Mbed Studio, using (GCC-ARM):
Compile [100.0%]: preprocessing.cpp
[Warning] processing.hpp@512,16: 'int ei::spectral::processing::find_fft_peaks(ei::matrix_i32_t*, ei::matrix_i32_t*, float, float, uint16_t)' defined but not used [-Wunused-function]
[Warning] processing.hpp@360,16: 'int ei::spectral::processing::find_fft_peaks(ei::matrix_t*, ei::matrix_t*, float, float, uint16_t)' defined but not used [-Wunused-function]
[Warning] processing.hpp@177,16: 'int ei::spectral::processing::i16_filter(ei::matrix_i16_t*, float, uint8_t, float, float, int)' defined but not used [-Wunused-function]
[Warning] processing.hpp@144,16: 'int ei::spectral::processing::butterworth_highpass_filter(ei::matrix_t*, float, float, uint8_t)' defined but not used [-Wunused-function]
[Warning] processing.hpp@115,16: 'int ei::spectral::processing::butterworth_lowpass_filter(ei::matrix_t*, float, float, uint8_t)' defined but not used [-Wunused-function]
Link: example-standalone-inferencing-mbed
c:/gnu_arm_embedded/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/preprocessing.o: in function `ei::ei_matrix::~ei_matrix()':
c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/./edge-impulse-sdk/dsp/numpy.hpp:1522: multiple definition of `ei::spectral::processing::spectral_power_edges(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float)'; BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/main.o:c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/./edge-impulse-sdk/dsp/spectral/processing.hpp:608: first defined here
c:/gnu_arm_embedded/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/preprocessing.o: in function `ei::spectral::processing::spectral_power_edges(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float)':
c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/././edge-impulse-sdk/dsp/spectral/processing.hpp:661: multiple definition of `ei::spectral::processing::spectral_power_edges(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float)'; BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/main.o:c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/./edge-impulse-sdk/dsp/spectral/processing.hpp:661: first defined here
c:/gnu_arm_embedded/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/preprocessing.o: in function `ei::spectral::processing::periodogram(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float, unsigned short)':
c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/././edge-impulse-sdk/dsp/spectral/processing.hpp:728: multiple definition of `ei::spectral::processing::periodogram(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float, unsigned short)'; BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/main.o:c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/./edge-impulse-sdk/dsp/spectral/processing.hpp:728: first defined here
c:/gnu_arm_embedded/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/preprocessing.o: in function `ei::spectral::processing::periodogram(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float, unsigned short)':
c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/././edge-impulse-sdk/dsp/spectral/processing.hpp:820: multiple definition of `ei::spectral::processing::periodogram(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float, unsigned short)'; BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/main.o:c:\Users\Kique\Mbed Programs\example-standalone-inferencing-mbed/./edge-impulse-sdk/dsp/spectral/processing.hpp:820: first defined here
[ERROR] c:/gnu_arm_embedded/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: BUILD/ARDUINO_NANO33BLE/GCC_ARM/source/preprocessing.o: in function `ei::ei_matrix::~ei_matrix()':
I would love to be able to benefit from those implementations, like the ones inside numpy.hpp, which I’m already using and are phenomenal.
The sdk is really rich but the documentation for this portion is just the comments inside the .hpp files so I would appreciate if you could also confirm this is a good structure for my preprocessing.hpp:
#ifndef _PREPROCESSING_H_
#define _PREPROCESSING_H_
#include "numpy.hpp"
#include "ei_model_types.h"
//#include "edge-impulse-sdk/dsp/spectral/processing.hpp" // linker errors
// Depending on your block:
typedef struct {
uint16_t implementation_version;
int axes;
float scale_axes;
bool center_data;
int filter_order;
float cutoff;
} ei_dsp_config_custom_t;
int extract_custom_block_features(signal_t *signal, matrix_t *output_matrix, void *config_ptr, const float f);
#endif // _PREPROCESSING_H_
Thanks in advance!
