I’m rewriting the Arduino example for my project. I want to use this example in a custom class instead of the main file. I include using #include <xxxxxx_inference.h> in my header file.
The problem is that I’m getting a lot of multiple definition error messages like the ones here, starting with ei::spectral::processing::spectral_power_edges.
Full error:
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In function
ei::spectral::processing ::spectral_power_edges(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float)': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/filters.hpp:121: multiple definition ofei::spectral::processing::spectral_power_edges(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float)’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/processing.hpp:608: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionei::spectral::processing::spectral_power_edges(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float)': c:\users\jurg\documents\arduino\libraries\ei-drilling-arduino-1.0.1\src\edge-impulse-sdk\dsp/numpy.hpp:895: multiple definition ofei::spectral::processing::spectral_power_edges(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float)’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/processing.hpp:661: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionei::spectral::processing::periodogram(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float, unsigned short)': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/processing.hpp:247: multiple definition ofei::spectral::processing::periodogram(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float, unsigned short)’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/processing.hpp:728: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionei::spectral::processing::periodogram(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float, unsigned short)': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/feature.hpp:172: multiple definition ofei::spectral::processing::periodogram(ei::ei_matrix_i16*, ei::ei_matrix_i16*, ei::ei_matrix_i16*, float, unsigned short)’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/processing.hpp:820: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionei_classifier_smooth_init(ei_classifier_smooth*, unsigned int, unsigned char, float, float)': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_classifier_smooth.h:53: multiple definition ofei_classifier_smooth_init(ei_classifier_smooth*, unsigned int, unsigned char, float, float)’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_classifier_smooth.h:53: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionei_classifier_smooth_update(ei_classifier_smooth*, ei_impulse_result_t*)': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_classifier_smooth.h:71: multiple definition ofei_classifier_smooth_update(ei_classifier_smooth*, ei_impulse_result_t*)’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_classifier_smooth.h:71: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionei_classifier_smooth_free(ei_classifier_smooth*)': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_classifier_smooth.h:141: multiple definition ofei_classifier_smooth_free(ei_classifier_smooth*)’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_classifier_smooth.h:141: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_moving_average_filter': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:135: multiple definition ofrun_moving_average_filter’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:135: first defined here
c:\Users\jurg
\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_classifier_init': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:169: multiple definition ofrun_classifier_init’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:169: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_inference': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:624: multiple definition ofrun_inference’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:624: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_classifier_continuous': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:190: multiple definition ofrun_classifier_continuous’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:190: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_inference_i16': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:888: multiple definition ofrun_inference_i16’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:888: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_classifier_image_quantized': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:1228: multiple definition ofrun_classifier_image_quantized’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:1228: first defined
here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_classifier': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:1001: multiple definition ofrun_classifier’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:1001: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/dsp_blocks.h:39: multiple definition ofei_dsp_blocks_i16' c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/dsp_blocks.h:39: first defined here c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/dsp_blocks.h:30: multiple definition ofei_dsp_blocks’
\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/dsp_blocks.h:30: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/model_metadata.h:180: multiple definition ofei_dsp_config_33' c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/model_metadata.h:180: first defined here c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/model_metadata.h:92: multiple definition ofei_classifier_inferencing_categories’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/model_metadata.h:92: first defined here
Error during build: exit status 1
IntelliSense configuration already up to date. To manually rebuild your IntelliSense configuration run “Ctrl+Alt+I”
[Error] Analyzing sketch ‘EdgeImpulse_inference2.ino’: Exit with code=1[Starting] Verifying sketch ‘EdgeImpulse_inference2.ino’
Please see the build logs in output path: c:\Users\jurg\Documents\sensor\build
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionei::spectral::processing::spectral_power_edges(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, ei ::ei_matrix*, float)': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/dsp/spectral/filters.hpp:121: multiple definition ofei::spectral::processing::spectral_power_edges(ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, ei::ei_matrix*, float)’
c:\Users
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_classifier_init': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:169: multiple definition ofrun_classifier_init’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(EdgeImpulse_inference2.ino.cpp.o): In functionrun_inference': C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge -impulse-sdk/classifier/ei_run_classifier.h:624: multiple definition ofrun_inference’
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/edge-impulse-sdk/classifier/ei_run_classifier.h:1228: first defined here
c:\Users\jurg\Documents\sensor\build\sketch\objs.a(Edge.cpp.o):C:\Users\jurg\Documents\Arduino\libraries\ei-drilling-arduino-1.0.1\src/model-parameters/dsp_blocks.h:30: first defined here
c:\Users
Can someone help me to get this working?
Jurg
