I am trying to use raspberry pi pico and ADXL343 accelerometer to do a gesture classification
Question/Issue: I have used accelerometer to detect my hand movement but it does not show xyz reading, instead it shows ADC reading. Can you help me to get readings of the xyz of hand movements
Project ID: 01
Context/Use case: use accelerometer to detect 4 types of gestures that represent 4 tones
Hello @shengyuehuili,
Could you explain how did you add the data to Edge Impulse?
That could help understand where the issue comes from.
Hi I have changed to a new microcontrollar it worked
I have the same problem. ADXL335 connect to pico but in Edge Impulse I don’t see this accelerometer or acceleration along x, y and z axis. What is causing this problem? how to fix it?
