How to deploy impulse on nRF5340 DK
I have a developed model on Edge Impulse. How to deploy it on nRF5340 DK?
  1. I tried to build this firmware: GitHub - edgeimpulse/firmware-nordic-nrf52840dk-nrf5340dk: Official Edge Impulse firmware for nRF52840 DK and nRF5340 DK. Build was failed.
  2. [Step 2]
  3. [Step 3]
Impulse will be running.
Not able to flash as build was unsuccessful.
  • [ ] Always
  • Platform: nRF5340 DK
  • Build Environment Details: Visual Studio Code 1.95.2
  • OS Version: Windows 11
  • Edge Impulse Version (Firmware):
  • Edge Impulse CLI Version:
  • Project Version:
Hi @iot_sm311 - thanks for submitting your question
Could you provide the steps you’re taking to build the firmware and the log of the error you’re facing?
