How do you connect Arduino Nano 33 BLE sense rev2
Hello sorry that I don’t really know much about how to do this stuff but I need to know once you open the flash.mac command and it opens the terminal i’ve already opened the bootloader and it doesn’t install the edge imipulse firmware not even after I put the edge impulse connect command in and edge impulse daemon. I’m also trying to do this with Porenta H7 can someone help me??
and also whenever I try to just go ahead because I noticed that it looks like it was already installed it says that theres no command that exists edge-impulse-daemon
which operating system? did you follow the steps in the link below? Arduino Nano 33 BLE Sense - Edge Impulse Documentation if the edge-impulse command is not available from the CLI, you need to ensure that the installation was successful.
We look forward to trying to help!
I use mac but the problem is if I do try doing that the terminal command it never installs it just says process complete and then once I stop the bootloader and try and open terminal to see if it’s just already installed it but it says that the edge impulse daemon command doesn’t exist
Hello @zm476,
Can you try to use the WebUSB feature to connect your board? https://www.edgeimpulse.com/blog/collect-sensor-data-straight-from-your-web-browser
I’m suspecting that the board is properly flashed but you have issues with your CLI.
You can try removing the CLI and install it again. Feel free to share a screenshot of the installation logs too.
Screenshot 2023-08-21 at 7.37.59 AM
it says that whenever I try to connect. How do I fix it.
Hello @zm476,
Your serial port is already open, can you quit the daemon and start again (or any other process that is reading your serial port).
how do I quit the daemon
and what other things might be accessing the serial port
Hello @zm476,
You can hit CMD+c or ctrl+c on your terminal with the daemon process running.
Arduino IDE Serial Console can be accessing your Serial Port too.
Here’s what it says now it’s still failing:
Screenshot 2023-08-21 at 7.55.36 AM
I don;t think that theres any mention of a serial port in this one so is there another problem??
Can you share the logs when you try to flash the board?
what do you mean by logs
@louis is Nano 33 ble sense rev2 supported because if it isn’t maybe that’s the problem
although that can’t be the case because my arduino portenta h7 also didn’t work and returned teh same error
This page says Rev2 is not supported yet. The Portenta is supported.
Assuming your serial port is manifested as a USB port, then start unplugging USB cords, retrying WebUSB, repeat until the port frees up.
I tried and it says the same thing do you know why @louis or @MMarcial
  • If the Serial Port is in use and you can’t figure out what is using it can you try on another physical machine.
  • Perhaps create a bootable version of Ubuntu and run under that OS.
Is there something I can use to find the serial port that’s being used
