GRU Model failing to train
CNN-GRU model failing to train successfully
During training
Summary:
I am trying to train a CNN-GRU classifier to compare to CNN only, but when I try to train the GRU it gets stuck in an infinite loop attaching to the job after packing the Tflite model.
Steps to Reproduce:
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
Expected Results:
Model training completes
Actual Results:
Infinite hang with message “Attaching to job #######…”
  • [X] Always
  • Platform: Arduino Portenta H7 Cortex-M7
Hi @drclee - welcome to the forum! I took a look at your project. It appears that your model is now training successfully. Let us know if that’s not the case. Cheers!
