Getting my sound event classification model to work on Arduino
I have a Sound Event Classification model created on EdgeImpulse able to detect the sound of a Toilet Flush from the rest (Noise). I have deployed the model as an Arduino .zip library and imported it in the Arduino IDE. With some compatibility issues, I finally got it uploaded on my Arduino Nano ESP 32. However, the problem now is that my model should do a real-time continuous Classification, but when I upload the sketch, on the serial monitor I see nothing. The Arduino already has an INMP-441 i2s microphone connected to it.
The code of the sketch is as follows:
 * SOFTWARE.
// These sketches are tested with 2.0.4 ESP32 Arduino Core
// https://github.com/espressif/arduino-esp32/releases/tag/2.0.4
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK   0
 ** NOTE: If you run into TFLite arena allocation issue.
 ** This may be due to may dynamic memory fragmentation.
 ** Try defining "-DEI_CLASSIFIER_ALLOCATION_STATIC" in boards.local.txt (create
 ** if it doesn't exist) and copy this file to
 ** `<ARDUINO_CORE_INSTALL_PATH>/arduino/hardware/<mbed_core>/<core_version>/`.
 ** See
 ** (https://support.arduino.cc/hc/en-us/articles/360012076960-Where-are-the-installed-cores-located-)
 ** to find where Arduino installs cores on your machine.
 ** If the problem persists then there's not enough memory for this model and application.
#include <WLB_TwoClasses_inferencing.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/i2s.h"
/** Audio buffers, pointers and selectors */
typedef struct {
    signed short *buffers[2];
    unsigned char buf_select;
    unsigned char buf_ready;
    unsigned int buf_count;
    unsigned int n_samples;
} inference_t;
static inference_t inference;
static const uint32_t sample_buffer_size = 2048;
static signed short sampleBuffer[sample_buffer_size];
static int print_results = -(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW);
static bool record_status = true;
void setup()
    Serial.begin(115200);
    while (!Serial);
    ei_printf("\tInterval: ");
    ei_printf_float((float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf(" ms.\n");
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    run_classifier_init();
    ei_sleep(2000);
    if (microphone_inference_start(EI_CLASSIFIER_SLICE_SIZE) == false) {
        ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
        return;
    ei_printf("Recording...\n");
 * @brief      Arduino main function. Runs the inferencing loop.
void loop()
    if (!m) {
        return;
    signal_t signal;
    signal.total_length = EI_CLASSIFIER_SLICE_SIZE;
    signal.get_data = &microphone_audio_signal_get_data;
    ei_impulse_result_t result = {0};
    EI_IMPULSE_ERROR r = run_classifier_continuous(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        return;
    if (++print_results >= (EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)) {
        // print the predictions
        ei_printf("Predictions ");
        ei_printf(": \n");
            ei_printf("    %s: ", result.classification[ix].label);
            ei_printf_float(result.classification[ix].value);
            ei_printf("\n");
        ei_printf("    anomaly score: ");
        ei_printf_float(result.anomaly);
        ei_printf("\n");
#endif
        print_results = 0;
static void audio_inference_callback(uint32_t n_bytes)
    for(int i = 0; i < n_bytes>>1; i++) {
        inference.buffers[inference.buf_select][inference.buf_count++] = sampleBuffer[i];
        if(inference.buf_count >= inference.n_samples) {
            inference.buf_select ^= 1;
            inference.buf_count = 0;
            inference.buf_ready = 1;
static void capture_samples(void* arg) {
  const int32_t i2s_bytes_to_read = (uint32_t)arg;
  size_t bytes_read = i2s_bytes_to_read;
  while (record_status) {
    /* read data at once from i2s */
    i2s_read((i2s_port_t)1, (void*)sampleBuffer, i2s_bytes_to_read, &bytes_read, 100);
    if (bytes_read <= 0) {
      ei_printf("Error in I2S read : %d", bytes_read);
    else {
        if (bytes_read < i2s_bytes_to_read) {
        ei_printf("Partial I2S read");
        // scale the data (otherwise the sound is too quiet)
        for (int x = 0; x < i2s_bytes_to_read/2; x++) {
            sampleBuffer[x] = (int16_t)(sampleBuffer[x]) * 8;
        if (record_status) {
            audio_inference_callback(i2s_bytes_to_read);
        else {
            break;
  vTaskDelete(NULL);
 * @brief      Init inferencing struct and setup/start PDM
 * @param[in]  n_samples  The n samples
 * @return     { description_of_the_return_value }
    inference.buffers[0] = (signed short *)malloc(n_samples * sizeof(signed short));
    if (inference.buffers[0] == NULL) {
        return false;
    inference.buffers[1] = (signed short *)malloc(n_samples * sizeof(signed short));
    if (inference.buffers[1] == NULL) {
        ei_free(inference.buffers[0]);
        return false;
    inference.buf_select = 0;
    inference.n_samples = n_samples;
    inference.buf_ready = 0;
    if (i2s_init(EI_CLASSIFIER_FREQUENCY)) {
        ei_printf("Failed to start I2S!");
    ei_sleep(100);
    xTaskCreate(capture_samples, "CaptureSamples", 1024 * 32, (void*)sample_buffer_size, 10, NULL);
    return true;
 * @brief      Wait on new data
 * @return     True when finished
    bool ret = true;
    if (inference.buf_ready == 1) {
        ei_printf(
            "Error sample buffer overrun. Decrease the number of slices per model window "
            "(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)\n");
        ret = false;
    while (inference.buf_ready == 0) {
        delay(1);
    return true;
 * Get raw audio signal data
    numpy::int16_to_float(&inference.buffers[inference.buf_select ^ 1][offset], out_ptr, length);
    return 0;
 * @brief      Stop PDM and release buffers
static void microphone_inference_end(void)
    i2s_deinit();
    ei_free(inference.buffers[1]);
static int i2s_init(uint32_t sampling_rate) {
  // Start listening for audio: MONO @ 8/16KHz
  i2s_config_t i2s_config = {
      .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_TX),
      .sample_rate = sampling_rate,
      .bits_per_sample = (i2s_bits_per_sample_t)16,
      .channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
      .communication_format = I2S_COMM_FORMAT_I2S,
      .intr_alloc_flags = 0,
      .dma_buf_count = 8,
      .dma_buf_len = 512,
      .use_apll = false,
      .tx_desc_auto_clear = false,
      .fixed_mclk = -1,
  i2s_pin_config_t pin_config = {
      .bck_io_num = 18,    // IIS_SCLK
      .ws_io_num = 10,     // IIS_LCLK
      .data_out_num = -1,  // IIS_DSIN
      .data_in_num = 17,   // IIS_DOUT
  esp_err_t ret = 0;
  ret = i2s_driver_install((i2s_port_t)1, &i2s_config, 0, NULL);
  if (ret != ESP_OK) {
    ei_printf("Error in i2s_driver_install");
  ret = i2s_set_pin((i2s_port_t)1, &pin_config);
    ei_printf("Error in i2s_set_pin");
  ret = i2s_zero_dma_buffer((i2s_port_t)1);
    ei_printf("Error in initializing dma buffer with 0");
  return int(ret);
static int i2s_deinit(void) {
    i2s_driver_uninstall((i2s_port_t)1); //stop & destroy i2s driver
    return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
The ID of my EdgeImpulse project is 1001180
  1. Upload the sketch
  2. Verify nothing happens
  3. [Step 3]
I should (or would like to) see on the serial monitor the live result of the classification of the audio feeded from the microphone to the board in real-time.
the serial monitor is empty
  • [ ] Always
  • **Platform:**Arduino Nano ESP32
  • Build Environment Details: Arduino IDE 2.3.8
  • **OS Version: Ubuntu 20.04
  • Custom Blocks / Impulse Configuration: the impulse has a MFE learning block and a NN classifier
    →Impulse configuration
hi @francescomennella !
the ESP32 sketch you have in Arduino examples is made for ESP-EYE board. It is likely that your microphone is a) different microphone b) connected differently - therefore the microphone configuration in the sketch does not work with your setup and crashes the board. You need to find an example of using ESP32 with the microphone you use and adapt this portion of the code to it
      .dma_buf_count = 8,
      .dma_buf_len = 512,
      .use_apll = false,
      .fixed_mclk = -1,
  esp_err_t ret = 0;
  return int(ret);
    return 0;
