Placuta care o folosesc : Seeed XIAO nRF52840 Sense
Folosesc Windows 10
Hello @alexandra_dolhascu1,
Could you provide some more information or share the code that you are using to print the raw data in your serial console please?
Am rezolvat problema. Multumesc frumos oricum!
- Copyright (c) 2022 EdgeImpulse Inc.
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the “Software”), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- SOFTWARE.
- @brief Sample & upload data to Edge Impulse Studio.
- @details Select 1 or multiple sensors by un-commenting the defines and select
- a desired sample frequency. When this sketch runs, you can see raw sample
- values outputted over the serial line. Now connect to the studio using the
edge-impulse-data-forwarderand start capturing data
#define SAMPLE_ACCELEROMETER
// #define SAMPLE_GYROSCOPE
// #define SAMPLE_ORIENTATION
// #define SAMPLE_ENVIRONMENTAL
// #define SAMPLE_ROTATION_VECTOR
- Configure the sample frequency. This is the frequency used to send the data
- to the studio regardless of the frequency used to sample the data from the
- sensor. This differs per sensors, and can be modified in the API of the sensor
#define FREQUENCY_HZ 10
/* Include ----------------------------------------------------------------- */
#include “Arduino_BHY2.h”
/* Constants --------------------------------------------------------------- */
#if (FREQUENCY_HZ <= 0)
#error “FREQUENCY_HZ should have a value greater dan 0”
#endif
#define INTERVAL_MS (1000 / FREQUENCY_HZ)
/* Forward declerations ---------------------------------------------------- */
void ei_printf(const char *format, …);
#ifdef SAMPLE_ACCELEROMETER
SensorXYZ accel(SENSOR_ID_ACC);
#endif
#ifdef SAMPLE_GYROSCOPE
SensorXYZ gyro(SENSOR_ID_GYRO);
#endif
#ifdef SAMPLE_ORIENTATION
SensorOrientation ori(SENSOR_ID_ORI);
#endif
#ifdef SAMPLE_ENVIRONMENTAL
Sensor temp(SENSOR_ID_TEMP);
Sensor baro(SENSOR_ID_BARO);
Sensor hum(SENSOR_ID_HUM);
Sensor gas(SENSOR_ID_GAS);
#endif
#ifdef SAMPLE_ROTATION_VECTOR
SensorQuaternion rotation(SENSOR_ID_RV);
#endif
void setup() {
/* Init serial */
Serial.begin(115200);
Serial.println(“Edge Impulse sensor data ingestion\r\n”);
/* Init & start sensors */
BHY2.begin(NICLA_I2C);
accel.begin();
#endif
gyro.begin();
#endif
#ifdef ORIENTATION
ori.begin();
#endif
temp.begin();
baro.begin();
hum.begin();
gas.begin();
#endif
rotation.begin();
#endif
void loop() {
BHY2.update();
delay(INTERVAL_MS);
ei_printf(“%f, %f, %f,”
,(accel.x() * 8.0 / 32768.0) * CONVERT_G_TO_MS2
,(accel.y() * 8.0 / 32768.0) * CONVERT_G_TO_MS2
,(accel.z() * 8.0 / 32768.0) * CONVERT_G_TO_MS2
#endif
,(gyro.x() * 8.0 / 32768.0) * CONVERT_G_TO_MS2
,(gyro.y() * 8.0 / 32768.0) * CONVERT_G_TO_MS2
,(gyro.z() * 8.0 / 32768.0) * CONVERT_G_TO_MS2
#endif
,ori.heading()
,ori.pitch()
,ori.roll()
#endif
ei_printf(“%.2f, %.2f, %.2f, %.2f,”
,temp.value()
,baro.value()
,hum.value()
,gas.value()
#endif
ei_printf(“%f, %f, %f, %f,”
,rotation.x()
,rotation.y()
,rotation.z()
,rotation.w()
#endif
ei_printf(“\r\n”);
@brief Printf function uses vsnprintf and output using Arduino Serial
@param[in] format Variable argument list
static char print_buf[1024] = { 0 };va_list args;
va_start(args, format);
va_end(args);if (r > 0) {
Serial.write(print_buf);
