Error on building with hardware acceleration rpi4
I am getting this error whenver i am trying to build with the hardware acceleration on rpi4
“APP_CUSTOM=1 TARGET_LINUX_AARCH64=1 USE_FULL_TFLITE=1 make -j”
I also made the following changes in the makefile:
Please tell me where am I going wrong?
@prarthana out of curiosity, try without the USE_FULL_TFLITE=1 to see what happens and then
TARGET_LINUX_ARMV7=1
I’m about to perform the same steps with docker on rpi4 and odroid n2+ with docker.
Questions
  1. Did you get the build flags from https://github.com/edgeimpulse/example-standalone-inferencing-linux?
  2. what is your host architecture?
Hello, thanks for replying
  1. Yes I tried to build the target from the link you shared with me.
  2. I also tried without using USE_FULL_TFLITE. However, I did not get an increase in speed in my program.
  3. Secondly my host architecture is aarch64( 64 bit RPI 4 with arm v8 architecture )
@prarthana check out the solution here
@inteladata thanks, I will look in this.
Thanks, alot.
