ERR: DeadlineExceeded - Job was active longer than specified deadline Try decreasing the number of windows or reducing the number of training cycles. If the error persists then you can contact support at hello@edgeimpulse.com to increase this time limit.
So i am training a simple model with 20 epochs and 0.15 learning rate but this keeps on appearing at the end of training. Any idea on how to fix this?
From what I see in your project, you haven’t labelled your images, you would need to label them in the “Labelling Queue” tab from the “Data Acquisition” view.
Also, I increased your compute time limit which was causing your issue.
I just updated your compute time limit to 60 minutes.
Your use case is cool
Do not hesitate to share your project and results with the community once you are happy with it!
