Hello everyone!
For the past few days, I’ve had the opportunity to experiment with an NVIDIA Jetson Nano. By following NVIDIA’s instructions, I was able to install JetPack 4.6.1 without any issues. My next step is to learn how to use Edge Impulse with the Nano, and I’ve decided to go through this tutorial. I found it while following the installation steps for Edge Impulse on the Nano.
However, I’m having issues with the setup script. Has anyone had the same problem or can help me? Thank you very much!
Best, Panx
No Project Started.
I want to connect my Jetson Nano to Edge Impulse.
Running the Setup Script:
wget -q -O - https://cdn.edgeimpulse.com/firmware/linux/jetson.sh | bash -
Connect to Edge Impulse with:
edge-impulse-linux
A wizard which will ask to log in on Edge Impulse.
Error Message:
bash: edge-impulse-linux: command not found
- [X] Always
- [ ] Sometimes
- [ ] Rarely
- Platform: NVIDIA Jetson Nano Developer Kit rev B01
- Build Environment Details: JetPack 4.6.1
- OS Version: Jetson Linux R32.7.1 / NVIDIA L4T 32.7.1 / Ubuntu 18.04
The errors after running the setup script are really a lot…
I paste here the last lines:
Run npm audit for details.
npm notice
npm notice New major version of npm available! 8.1.2 → 11.5.2
npm notice Changelog: githubcom/npm/cli/releases/tag/v11.5.2
npm notice Run npm install -g npm@11.5.2 to update!
npm notice
npm WARN EBADENGINE Unsupported engine {
npm WARN EBADENGINE package: ‘npm-registry-fetch@17.1.0’,
npm WARN EBADENGINE required: { node: ‘^16.14.0 || >=18.0.0’ },
npm WARN EBADENGINE current: { node: ‘v16.13.1’, npm: ‘8.1.2’ }
npm WARN EBADENGINE }
npm WARN EBADENGINE package: ‘@aws-sdk/util-locate-window@3.804.0’,
npm WARN EBADENGINE required: { node: ‘>=18.0.0’ },
npm WARN EBADENGINE package: ‘@npmcli/redact@2.0.1’,
npm WARN EBADENGINE package: ‘make-fetch-happen@13.0.1’,
npm WARN EBADENGINE package: ‘npm-package-arg@11.0.3’,
npm WARN EBADENGINE package: ‘@npmcli/agent@2.2.2’,
npm WARN EBADENGINE package: ‘cacache@18.0.4’,
npm WARN EBADENGINE package: ‘hosted-git-info@7.0.2’,
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See v8dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see githubcom/request/request/issues/3142
npm WARN deprecated multer@1.4.5-lts.1: Multer 1.x is impacted by a number of vulnerabilities, which have been patched in 2.x. You should upgrade to the latest 2.x version.
npm ERR! code 1
npm ERR! path /usr/local/lib/node_modules/edge-impulse-linux/node_modules/koffi
npm ERR! command failed
npm ERR! command sh -c node src/cnoke/cnoke.js -p . -d src/koffi --prebuild
npm ERR! >> Using CMake binary: cmake
npm ERR! >> Node: 16.13.1
npm ERR! >> Target: linux_arm64
npm ERR! >> Using local node-api headers
npm ERR! >> Running configuration
npm ERR! Not searching for unused variables given on the command line.
npm ERR! – The C compiler identification is GNU 7.5.0
npm ERR! – The CXX compiler identification is GNU 7.5.0
npm ERR! – The ASM compiler identification is GNU
npm ERR! – Found assembler: /usr/bin/cc
npm ERR! – Check for working C compiler: /usr/bin/cc
npm ERR! – Check for working C compiler: /usr/bin/cc – works
npm ERR! – Detecting C compiler ABI info
npm ERR! – Detecting C compiler ABI info - done
npm ERR! – Detecting C compile features
npm ERR! – Detecting C compile features - done
npm ERR! – Check for working CXX compiler: /usr/bin/c++
npm ERR! – Check for working CXX compiler: /usr/bin/c++ – works
npm ERR! – Detecting CXX compiler ABI info
npm ERR! – Detecting CXX compiler ABI info - done
npm ERR! – Detecting CXX compile features
npm ERR! – Detecting CXX compile features - done
npm ERR! – Performing Test use_no_finite_loops
npm ERR! – Performing Test use_no_finite_loops - Failed
npm ERR! – Configuring incomplete, errors occurred!
npm ERR! See also “/usr/local/lib/node_modules/edge-impulse-linux/node_modules/koffi/build/koffi/linux_arm64/v16.13.1_arm64/CMakeFiles/CMakeOutput.log”.
npm ERR! See also “/usr/local/lib/node_modules/edge-impulse-linux/node_modules/koffi/build/koffi/linux_arm64/v16.13.1_arm64/CMakeFiles/CMakeError.log”.
npm ERR! Failed to load prebuilt binary, rebuilding from source
npm ERR! CMake Error at CMakeLists.txt:23 (cmake_policy):
npm ERR! Policy “CMP0091” is not known to this version of CMake.
npm ERR!
npm ERR!
npm ERR! Error: Failed to run configure step
npm ERR! at Builder.configure (/usr/local/lib/node_modules/edge-impulse-linux/node_modules/koffi/src/cnoke/src/builder.js:227:19)
npm ERR! at Builder.build (/usr/local/lib/node_modules/edge-impulse-linux/node_modules/koffi/src/cnoke/src/builder.js:243:24)
npm ERR! at processTicksAndRejections (node:internal/process/task_queues:96:5)
npm ERR! at async main (/usr/local/lib/node_modules/edge-impulse-linux/node_modules/koffi/src/cnoke/cnoke.js:145:9)
