I keep receiving the following when trying to flash Edge Impulse firmware:
You need to upgrade your Arduino CLI version (now: 0.33.1, but required: 0.33.x or higher)
Have tried multiple different versions of Arduino cli to no avail.
Hi @Rshaw7
a fix is on the way, meanwhile in flash_windows.bat can you try to change this line
if (!CLI_MAJOR! LEQ !EXPECTED_CLI_MAJOR!) if (!CLI_MINOR! LSS !EXPECTED_CLI_MINOR!) GOTO UPGRADECLI
to
if !CLI_MAJOR! LEQ !EXPECTED_CLI_MAJOR! if !CLI_MINOR! LSS !EXPECTED_CLI_MINOR! GOTO UPGRADECLI
thank you
Thanks Francesco, that solved the problem!
glad it worked!
thank you for testing, the fix should be available soon.
