Edge-impulse-daemon "Failed to upload to Ingestion API"
When I follow the guide for the nRF54L15 + X-NUCLEO-IKS02A1, edge-impulse-daemon fails to upload the accelerometer data to the Ingestion API.
This bug is relevant to anyone who follows the nRF54L15 guide.
Steps to Reproduce:
  1. Install edge-impulse-cli
  2. Follow the nRF54L15 guide
  3. Open up the project page that edge-impulse-daemon outputs
  4. Start sampling accelerometer data
  5. When sampling finishes, edge-impulse-daemon will fail to upload the data.
Expected Results:
I expect edge-impulse-daemon to either successfully upload the data, or provide me with a file to upload to the studio myself.
Always
  • Platform: nRF54L15 DK
  • Build Environment Details: NA
  • OS Version: Windows 11 and Linux (NixOS)
  • Edge Impulse Version (Firmware): v0.0.0
  • Edge Impulse CLI Version: 1.39.2
  • Project Version: No versions created yet
  • Custom Blocks / Impulse Configuration: NA
    edge-impulse-daemon output on Windows:
Edge Impulse serial daemon v1.39.2
Endpoints:
    API:       https://studio.edgeimpulse.com
? Which device do you want to connect to? (šŸ” type to search) COM7
[SER] Connecting to COM7
[SER] Retrieved configuration
[SER] Device is running AT command version 1.8.0
[SER] Device is not connected to remote management API, will use daemon
[WS ] Device "nRF54L15" is now connected to project "Anthony24851-project-1". To connect to another project, run `edge-impulse-daemon --clean`.
[WS ] Go to https://studio.edgeimpulse.com/studio/1048257/acquisition/training to build your machine learning model!
  path: '/api/training/data',
  label: 'Test',
  length: 10000,
  interval: 10,
  hmacKey: 'hidden',
  sensor: 'Accelerometer'
[SER] Configured upload settings
[SER] Sampling started
[SER] Sampling done
[SER] Device not connected to WiFi directly, reading from buffer (bytes 0 - 16071, expecting to read ~21428 bytes...
[SER] Reading 46% complete...
[SER] Reading 99% complete...
[SER] Reading from buffer OK
[SER] File is 16071 bytes after decoding
[SER] Uploading to https://ingestion.edgeimpulse.com/api/training/data
[SER] Failed to upload to https://ingestion.edgeimpulse.com/api/training/data Error: Failed to upload: 400 Bad Request
    at SerialDevice.sampleRequest (C:\Users\user\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\daemon.js:409:35)
    at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
    at async WebSocket.<anonymous> (C:\Users\user\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli-common\remote-mgmt-service.js:247:21)
Note: daemon.js:409:35 corresponds to this line in the edge-impulse-cli repo.
Hi @Anthony24851 - I’m looking into this one for you. Hang tight!
OK, one thing to try as a simple fix first. Have you tried running the daemon with the clean flag and reconnecting to the project?
If not, that is a good first step. In the meantime, I will connect with our embedded team.
That command fixed the issue. Thank you!
Awesome! Great to hear.
Unfortunately, I have to reopen this bug report because edge-impulse-daemon --clean does not fix the issue. The issue is actually random, and happens 50% of the time even if I run edge-impulse-daemon --clean between every sample.
