now i am getting these errors continously even after updating the edge impulse cli
[SER] Connecting to COM5
Hello @01fe20bec237,
Did you uploaded the Edge Impulse firmware to your device correctly? Which hardware target are you using by the way?
The issue can also come from a bad usb cable.
I am attempting to connect my Arduino Nano with plate number 1 to Edge Impulse. I am using Ubuntu 22.04 operating system and following the steps for the setup provided below :
I am getting the below error when installing edge impulse cli
(base) nelum@nelum-X510UA:~$ npm install -g edge-impulse-cli
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
changed 378 packages in 31s
14 packages are looking for funding
run npm fund for details
When installing the CLI using npm, I get these depreciation warnings, but no errors. (I have attempted reinstalling the CLI and got the same result.
$ npm install -g edge-impulse-cli --force
npm warn using --force Recommended protections disabled.
(node:41114) ExperimentalWarning: CommonJS module /home/linuxbrew/.linuxbrew/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /home/linuxbrew/.linuxbrew/lib/node_modules/npm/node_modules/supports-color/index.js using require().
Support for loading ES Module in require() is an experimental feature and might change at any time
(Use `node --trace-warnings ...` to show where the warning was created)
npm warn deprecated osenv@0.1.5: This package is no longer supported.
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated move-concurrently@1.0.1: This package is no longer supported.
npm warn deprecated @zeit/dockerignore@0.0.5: "@zeit/dockerignore" is no longer maintained
npm warn deprecated rimraf@2.7.1: Rimraf versions prior to v4 are no longer supported
npm warn deprecated figgy-pudding@3.5.2: This module is no longer supported.
npm warn deprecated npmlog@4.1.2: This package is no longer supported.
npm warn deprecated har-validator@5.1.5: this library is no longer supported
npm warn deprecated copy-concurrently@1.0.5: This package is no longer supported.
npm warn deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
npm warn deprecated fs-write-stream-atomic@1.0.10: This package is no longer supported.
npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm warn deprecated gauge@2.7.4: This package is no longer supported.
npm warn deprecated @xmldom/xmldom@0.8.8: this version has critical issues, please update to the latest version
npm warn deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
added 529 packages in 17s
48 packages are looking for funding
run `npm fund` for details
When attempting to run the CLI, the daemon is not found by npm
$ edge-impulse-daemon
node:internal/modules/cjs/loader:1242
throw err;
Error: Cannot find module '/mnt/c/Users/dmull/AppData/Roaming/npm/node_modules/edge-impulse-cli/build/cli/daemon.js'
at Function._resolveFilename (node:internal/modules/cjs/loader:1239:15)
at Function._load (node:internal/modules/cjs/loader:1064:27)
at TracingChannel.traceSync (node:diagnostics_channel:322:14)
at wrapModuleLoad (node:internal/modules/cjs/loader:218:24)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:170:5)
at node:internal/main/run_main_module:36:49 {
code: 'MODULE_NOT_FOUND',
requireStack: []
Node.js v23.3.0
I’ve tried reinstalling node/npm with the same result. Any tips on how to get the daemon to install? Most of the tips I’ve seen are reinstalling node and the CLI, but I’ve already tried those
