I’ve tried to install Edge impulse CLI a few times over the last days, but it didn’t ended up working.
I’ve followed other threads with the same type of error, but it doesn’t seem to fix it.
I ended up using Chocolatey from GitHub - edgeimpulse/ei-install-scripts: Set up an environment for running the Edge Impulse CLI and my actual error log is:
PS C:\arduino> Set-ExecutionPolicy Bypass -Scope Process -Force; [System.Net.ServicePointManager]::SecurityProtocol = [System.Net.ServicePointManager]::SecurityProtocol -bor 3072; iwr -Uri “https://raw.githubusercontent.com/edgeimpulse/ei-install-scripts/main/install-windows.ps1” -Outfile install.ps1; iex .\install.ps1; del .\install.ps1
[^^] Refreshed Environment
[^^] Running as admin on amd64
[><] Edge Impulse CLI is not installed.
Checking if you have Node.js v12 or higher installed…
[^^] Node.js v14.18.1 installed!
Checking if you have Python 3.7 or higher installed…
[^_^] Python 3.12.0 installed!
Downloading the Build Tools for Windows bootstrapper, this may take a few minutes…
Checking your Build Tools for Windows configuration. This may take several minutes…
Installing the Edge Impulse CLI…
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See There’s Math.random(), and then there’s Math.random() · V8 for details.
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (ReDos Vulnerability Regression Visibility Notice · Issue #797 · debug-js/debug · GitHub)
C:\Users\Joselito\AppData\Roaming\npm\edge-impulse-uploader → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\uploader.js
C:\Users\Joselito\AppData\Roaming\npm\edge-impulse-blocks → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\blocks.js
C:\Users\Joselito\AppData\Roaming\npm\edge-impulse-daemon → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\daemon.js
C:\Users\Joselito\AppData\Roaming\npm\edge-impulse-run-impulse → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\run-impulse.js
C:\Users\Joselito\AppData\Roaming\npm\edge-impulse-data-forwarder → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\data-forwarder.js
C:\Users\Joselito\AppData\Roaming\npm\eta-flash-tool → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\eta-flash-tool\flashtool.js
C:\Users\Joselito\AppData\Roaming\npm\himax-flash-tool → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\himax-flash-tool\flashtool.js
C:\Users\Joselito\AppData\Roaming\npm\edge-impulse-framebuffer2jpg → C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\framebuffer-to-jpg.js
@serialport/bindings@8.0.8 install C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=14.18.1 runtime=node arch=x64 libc= platform=win32)
C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings>if not defined npm_config_node_gyp (node “C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\…..\node_modules\node-gyp\bin\node-gyp.js” rebuild )  else (node “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” rebuild )
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\gyp_main.py”, line 50, in
sys.exit(gyp.script_main())
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp_init_.py”, line 554, in script_main
return main(sys.argv[1:])
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp_init_.py”, line 547, in main
return gyp_main(args)
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp_init_.py”, line 520, in gyp_main
[generator, flat_list, targets, data] = Load(
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp_init_.py”, line 136, in Load
result = gyp.input.Load(build_files, default_variables, includes[:],
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp\input.py”, line 2782, in Load
LoadTargetBuildFile(build_file, data, aux_data,
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp\input.py”, line 391, in LoadTargetBuildFile
build_file_data = LoadOneBuildFile(build_file_path, data, aux_data,
File “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\pylib\gyp\input.py”, line 234, in LoadOneBuildFile
build_file_contents = open(build_file_path, ‘rU’).read()
ValueError: invalid mode: ‘rU’ while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: gyp failed with exit code: 1
gyp ERR! stack     at ChildProcess.onCpExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:351:16)
gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
gyp ERR! System Windows_NT 10.0.19045
gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
gyp ERR! cwd C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
gyp ERR! node -v v14.18.1
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN tsargs@1.4.1 requires a peer of typescript@^3.1.6 but none is installed. You must install peer dependencies yourself.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     C:\Users\Joselito\AppData\Roaming\npm-cache_logs\2023-10-09T18_47_39_004Z-debug.log
internal/modules/cjs/loader.js:905
throw err;
Error: Cannot find module ‘C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\blocks.js’
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
at Function.Module.load (internal/modules/cjs/loader.js:746:27)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
at internal/main/run_main_module.js:17:47 {
code: ‘MODULE_NOT_FOUND’,
requireStack: []
I’ve tryied many solutions but this “Cannot find module ‘C:\Users\Joselito\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\blocks.js’” seems to be the problem.
thanks in advance!
