Edge-impulse-cli installation error on ubuntu 24.04
HI,
I am trying to install edge-impulse-cli on ubuntu 24.04. But it’s not going well.
There seem to be several cases of installation failure, but the symptoms vary and I have not been able to find a solution.
The execution results are shown below. Please let me know if there is anything I should check.
Thanks.
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 24.04.1 LTS
Release:	24.04
Codename:	noble
$ python3 -V
Python 3.12.3
$ node -v
v20.18.1
$ npm config get prefix
/usr
$ sudo npm install -g edge-impulse-cli
npm warn deprecated osenv@0.1.5: This package is no longer supported.
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated move-concurrently@1.0.1: This package is no longer supported.
npm warn deprecated @zeit/dockerignore@0.0.5: "@zeit/dockerignore" is no longer maintained
npm warn deprecated rimraf@2.7.1: Rimraf versions prior to v4 are no longer supported
npm warn deprecated figgy-pudding@3.5.2: This module is no longer supported.
npm warn deprecated npmlog@4.1.2: This package is no longer supported.
npm warn deprecated har-validator@5.1.5: this library is no longer supported
npm warn deprecated copy-concurrently@1.0.5: This package is no longer supported.
npm warn deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
npm warn deprecated fs-write-stream-atomic@1.0.10: This package is no longer supported.
npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
npm warn deprecated gauge@2.7.4: This package is no longer supported.
npm warn deprecated fstream@1.0.12: This package is no longer supported.
npm warn deprecated @xmldom/xmldom@0.8.8: this version has critical issues, please update to the latest version
npm warn deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
npm error code 1
npm error path /usr/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
npm error command failed
npm error command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm error gyp info it worked if it ends with ok
npm error gyp info using node-gyp@10.1.0
npm error gyp info using node@20.18.1 | linux | x64
npm error gyp info find Python using Python version 3.12.3 found at "/usr/bin/python3"
npm error gyp info spawn /usr/bin/python3
npm error gyp info spawn args [
npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
npm error gyp info spawn args 'binding.gyp',
npm error gyp info spawn args '-f',
npm error gyp info spawn args 'make',
npm error gyp info spawn args '-I',
npm error gyp info spawn args '/usr/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/config.gypi',
npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
npm error gyp info spawn args '/root/.cache/node-gyp/20.18.1/include/node/common.gypi',
npm error gyp info spawn args '-Dlibrary=shared_library',
npm error gyp info spawn args '-Dvisibility=default',
npm error gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/20.18.1',
npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
npm error gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/20.18.1/<(target_arch)/node.lib',
npm error gyp info spawn args '-Dmodule_root_dir=/usr/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings',
npm error gyp info spawn args '-Dnode_engine=v8',
npm error gyp info spawn args '--depth=.',
npm error gyp info spawn args '--no-parallel',
npm error gyp info spawn args '--generator-output',
npm error gyp info spawn args 'build',
npm error gyp info spawn args '-Goutput_dir=.'
npm error gyp info spawn args ]
npm error gyp ERR! build error
npm error gyp ERR! stack Error: not found: make
npm error gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/lib/index.js:16:17)
npm error gyp ERR! stack at which (/usr/lib/node_modules/npm/node_modules/which/lib/index.js:77:9)
npm error gyp ERR! stack at async doWhich (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:112:22)
npm error gyp ERR! stack at async loadConfigGypi (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:77:7)
npm error gyp ERR! stack at async build (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:35:3)
npm error gyp ERR! stack at async run (/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js:81:18)
npm error gyp ERR! System Linux 6.8.0-49-generic
npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
npm error gyp ERR! cwd /usr/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
npm error gyp ERR! node -v v20.18.1
npm error gyp ERR! node-gyp -v v10.1.0
npm error gyp ERR! not ok
npm error A complete log of this run can be found in: /root/.npm/_logs/2024-11-21T01_57_48_889Z-debug-0.log
Hi @kumagai,
Try installing build-essential and retry installing edge-impulse-cli
$ sudo apt-get install build-essential
// Raul James
Hi @rjames,
Thank you for your quick response.
It went well!
In my environment,
$ edge-impulse-data-forwarder
It gets “permission denied”, so I did chmod 775 .js files in /usr/lib/node_modules/edge-impulse-cli/build/cli/.
It works. The above was just a quick report.
Ah, thank you so much! I was scouring Google for things and could not find answers. I just setup WSL2 for the first time and was following the installation steps exactly so I wasn’t sure why it wasn’t working!
Did this and it was all good. Got stuck on this all day yesterday!
