I am trying to integrate my Edge Impulse inference engine (C++ library + compiled model) directly into custom MicroPython firmware for the Raspberry Pi Pico. However, when I build the firmware with the inference library included, the final .uf2 file becomes too large (~1.9 MB) and the board does not boot after flashing — there is no serial output and the device does not enumerate over USB.
The goal is to provide an integrated firmware that includes both the MicroPython interpreter and the native inference engine as a module.
- Built the inference library (
ei_inference) in C++ with the Pico SDK — standalone version works fine. - Verified the compiled model runs correctly on the Pico with a native C++ application.
- Tried to compile a custom MicroPython build using the official MicroPython port for RP2040, adding the
ei_inferencestatic library and model as a custom C module. - The firmware compiled successfully but produced a
.uf2file ~1.9 MB in size. - After flashing, the board does not enumerate over USB, no serial output appears, and the device appears bricked until reflashed with standard MicroPython.
The Pico should boot into MicroPython with the custom inference module available (import ei_inference) so students can run inference calls directly from Python scripts.
The device does not boot at all.
No serial device appears, and no REPL output.
The Pico must be reflashed with plain MicroPython to work again.
—Always
… Sometimes
…Rarely
Platform: Raspberry Pi Pico (RP2040)
Build Environment Details:
- Pico SDK v1.5.1
- Custom MicroPython build using
mpy-crossandmakeon macOS 13 - Edge Impulse C++ library and compiled model embedded as static library in MicroPython build
OS Version: macOS 13.5.2 (also tested on Ubuntu 22.04)
Custom Blocks / Impulse Configuration:
- 3-axis raw accelerometer data, small NN classifier, compiled with CMSIS-NN and TFLM micro kernels.
- No custom DSP blocks.
I want to confirm:
- Is this approach feasible for the Pico (2 MB flash limit)?
- Any tips for reducing size (e.g., exclude unused modules, shrink model, other linker flags)?
