🔥 Critical ESP32-S3 Failure: My Own EfficientNet Lite (Int8) TFLite is Stuck with Constant Output.
I’m developing an audio classification project using the Edge Impulse SDK on an ESP32-S3 with ESP-IDF. I am encountering a severe inference issue after replacing the default TFLite file with a custom model.
The issue is that my custom-trained model, despite matching the input/output dimensions, consistently returns a near-constant, biased prediction for one class, and performance is extremely poor.
I replaced the original TFLite model (likely a MobilenetV2) in the SDK example with my own custom EfficientNet Lite model. The generated SDK files show the original model was using 8-bit integer quantization (Int8) for the learning block and classification.
My custom TFLite model was trained externally in TensorFlow. Even after converting it to TFLite (I have tested both Float32 and an equivalent Int8 quantized version), the inference on the ESP32-S3 using the Edge Impulse SDK runtime returns an almost constant, high prediction for class 1 (approx. 0.99973), regardless of the audio input.
The logs show:
I (327196) EI_TASK: Timing: DSP 78 ms, Inference 232 ms, Anomaly 0 ms I (327196) EI_TASK: Predictions: I (327196) EI_TASK: classe 1: 0.99973 I (327196) EI_TASK: classe 2: 0.00027
(The 9489 ms inference time is also unacceptably high for this platform.)
840129 (Extracted from ei_classifier_model_variables.h)
Real-time audio classification (distinguishing “dabi” vs. “oi_dabi”). I need to deploy an efficient, custom-trained model (EfficientNet Lite) on a low-power, constrained microcontroller (ESP32-S3).
  1. Downloaded the Edge Impulse Audio Classification SDK example.
  2. Trained a custom EfficientNet Lite model offline in TensorFlow using a balanced audio dataset.
  3. The DSP settings (Audio MFE) used in my TensorFlow pipeline match the configuration in the generated code (e.g., num_filters=40, frame_length=0.02f, etc.).
  4. Converted the model to TFLite. I have been careful to ensure the input/output shapes are correct.
  5. Replaced the original TFLite file with my custom TFLite.
  6. Compiled and deployed using ESP-IDF for the ESP32-S3.
The EfficientNet Lite model should load and perform inference correctly, yielding varying probability scores that accurately classify the input audio, reflecting its strong performance in the validation set.
The model produces a near-constant output for class 1 and exhibits an extremely long inference time (~9.5 seconds).
  • [x] Always
  • Platform: ESP32-S3
  • Build Environment Details: ESP-IDF
  • OS Version: [e.g., Ubuntu 22.04, Windows 10 - Please fill this in]
  • Edge Impulse Version (Firmware): [Please find this version]
  • Edge Impulse CLI Version: [Please find this version]
  • Project Version: 2 (Extracted from deploy_version)
  • Custom Blocks / Impulse Configuration:
    • DSP Block: Audio MFE (Input Size: 3960 features).
    • Model Configuration Details (from generated code):
      • quantized = 1 (Model is expected to be Int8 Quantized)
      • postprocess_fn = &process_classification_i8
      • zero_point = -128, scale = 0.00390625 (Crucial post-processing parameters)
[Include the TFLite file if possible, or a screenshot of the Netron viewer showing its input/output layers and data types (Int8 or Float32).]
Given the constant output and the high inference time, I strongly suspect a quantization mismatch or data handling issue in the Edge Impulse TFLite runtime:
  1. Quantization Mismatch: Even if I provide an Int8 TFLite model, the Zero Point and Scale values used by the original EI model (zero_point = -128, scale = 0.00390625) may not match the zero point and scale of my custom Int8 TFLite model, causing incorrect dequantization and constant output.
  2. Model Compatibility: The TFLite runtime on the ESP32-S3 might not fully support all EfficientNet Lite operators in the generated SDK wrapper, leading to slow fallback or broken inference.
Could you please confirm the requirements for custom Int8 TFLite models, especially regarding the necessary Zero Point and Scale values, or if there’s a known compatibility issue with EfficientNet Lite on the ESP32-S3 using the EI SDK?
Hi, @Betao !
First of all thank you for taking the time to give us feedback. A few points:
  1. While there is nothing inherently wrong with using generative AI for writing feedback, you need to at least read what the LLM wrote and check if everything is correct. I can understand that the text was written by an LLM from a text prompt and some debug output - the suggestions LLM gave you (e.g. [Please find this version]) were left unaddressed. Additionally the LLM makes some confusing observations about inference time:
The logs show:
I can see that inference time is 232 ms. - and not 9489 ms. Was it simply hallucinated by an LLM? I think so. What else was hallucinated? I don’t know.
  1. Closely related to this - LLMs often validate users through a behavior called sycophancy meaning they tend to agree with or flatter users, even if the user is wrong, because they’re trained to be helpful and align with human preferences during training (RLHF). The LLM does not have deep understanding of Edge Impulse Platform and it is trained to agree with the user, so it points at possible quantization mismatch or data handling issue. In reality we should start addressing the issue with much more simpler things.
  2. For the things I actually need:
First of all, apologies for the confusion in my previous message. I relied too much on LLM-generated text and didn’t validate it carefully enough before posting, which led to inaccuracies. Thanks for pointing that out.
Let me clearly explain the workflow I used and where I believe the issue comes from.
First, I trained a wake word model directly inside Edge Impulse, using the platform’s own tools and DSP (Audio MFE). I then exported the C++ SDK for the ESP32-S3 and deployed it — and this worked perfectly, with correct predictions and reasonable inference times.
As a second step, I wanted to experiment with custom-trained models. I trained my own wake word model externally in TensorFlow and then simply replaced the .tflite file inside the generated SDK, keeping the same C++ inference pipeline. After doing this, the model started producing the meaningless output I described earlier (near-constant prediction for one class).
Based on this behavior, I believe the issue is not the SDK itself, but rather how I am generating the Audio MFE features during training. Currently, I generate MFE features in Python using TensorFlow-based functions, which are not bit-exactly the same implementation as the DSP used in the Edge Impulse C++ SDK. I suspect this DSP mismatch is what leads to the constant and incorrect predictions during inference.
Because of that, I’d like to train my own models while keeping full DSP consistency. I noticed that Edge Impulse provides the processing-blocks repository on GitHub, which contains the exact DSP implementations used by the platform.
My question is:
Do you agree that integrating the Edge Impulse processing-blocks DSP code into my training pipeline to generate MFE features, then exporting the trained model to TFLite and deploying it in the C++ SDK on the ESP32-S3, should result in correct and consistent inference?
The goal is to keep the DSP identical end-to-end, while only moving the model training outside the platform.
Thanks again for your time and guidance.
@Betao ,
Yes, of course you cannot simply swap .tflite file without making sure DSP is the same.
More important question for me as an engineer I guess is - why do you want to take the training outside the platform? Is there something missing from our platform?
First of all, I must say that your platform is sensational. It is truly an incredible initiative that has helped me a lot to successfully embed AI into a microcontroller. The main reason I chose to train externally is to have more specific control over the pipeline. For example, I could not find features like cross-validation directly in the interface. Also, regarding pre-trained models, the most complex one I found on the free version was MobileNet V2 0.35; I wanted to test others, even though I have observed that the ESP32 takes significantly longer to infer with heavier models due to hardware limitations. Finally, I am performing data augmentation by mixing random sounds with my dataset, and training externally gives me the granular control I need for this specific mixing process.
