While trying to follow the guide as attached here ( TinyML Made Easy: Object Detection with XIAO ESP32S3 Sense - Hackster.io
The Xiao ESP32-S3-Sense runs into the following death loop
assert failed: multi_heap_free multi_heap_poisoning.c:279 (head != NULL)
Backtrace: 0x4037b36d:0x3fceb800 0x4037b335:0x3fceb820 0x4038179a:0x3fceb840 0x4038042f:0x3fceb980 0x403764df:0x3fceb9a0 0x40381839:0x3fceb9c0 0x42008199:0x3fceb9e0 0x4200c5f9:0x3fceba00 0x42003d99:0x3fceba20 0x42003f42:0x3fcebb20 0x42004231:0x3fcebb40 0x42004625:0x3fcebbf0 0x420046dd:0x3fcebc10 0x4200eee0:0x3fcebcc0 0x4037c011:0x3fcebce0
ELF file SHA256: 052f18423
To get a starting point and feel for the Edge Impulse pipeline so we can build on it further
- Browse similar thread on the forums especially pertaining to my specific issue
- Tried letting LLMs give this a shot
- Tried swapping between TFLite and EON Compiler
Expected the model to work as suggested in the tutorial
The corrupt heap error
- [ ] Always
- Platform: Xiao ESP32-S3-Sense
- Build Environment Details: Arduino IDE 2.3.6, ESP32 (by espressif) 3.3.1
- OS Version: NA
- Edge Impulse Version (Firmware):
#define EI_STUDIO_VERSION_MAJOR 1
#define EI_STUDIO_VERSION_MINOR 9
#define EI_STUDIO_VERSION_PATCH 9
- Edge Impulse CLI Version: NA
- Project Version: 1
Custom Blocks / Impulse Configuration: NA
These are the following settings that I am using while flashing
My Current code looks like this:
* SOFTWARE.
// These sketches are tested with 2.0.4 ESP32 Arduino Core
// https://github.com/espressif/arduino-esp32/releases/tag/2.0.4
#include <XIAO-ESP32S3-Sense-Object_Detection_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 10
#define SIOD_GPIO_NUM 40
#define SIOC_GPIO_NUM 39
#define Y9_GPIO_NUM 48
#define Y8_GPIO_NUM 11
#define Y7_GPIO_NUM 12
#define Y6_GPIO_NUM 14
#define Y5_GPIO_NUM 16
#define Y4_GPIO_NUM 18
#define Y3_GPIO_NUM 17
#define Y2_GPIO_NUM 15
#define VSYNC_GPIO_NUM 38
#define HREF_GPIO_NUM 47
#define PCLK_GPIO_NUM 13
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
.pin_pwdn = PWDN_GPIO_NUM,
.pin_reset = RESET_GPIO_NUM,
.pin_xclk = XCLK_GPIO_NUM,
.pin_d7 = Y9_GPIO_NUM,
.pin_d6 = Y8_GPIO_NUM,
.pin_d5 = Y7_GPIO_NUM,
.pin_d4 = Y6_GPIO_NUM,
.pin_d3 = Y5_GPIO_NUM,
.pin_d2 = Y4_GPIO_NUM,
.pin_d1 = Y3_GPIO_NUM,
.pin_d0 = Y2_GPIO_NUM,
.pin_vsync = VSYNC_GPIO_NUM,
.pin_href = HREF_GPIO_NUM,
.pin_pclk = PCLK_GPIO_NUM,
.xclk_freq_hz = 20000000,
.ledc_timer = LEDC_TIMER_0,
.frame_size = FRAMESIZE_QVGA, //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
.fb_count = 1, //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
void setup()
Serial.begin(115200);
while (!Serial);
else {
ei_sleep(2000);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
void loop()
return;
if(snapshot_buf == nullptr) {
return;
ei::signal_t signal;
free(snapshot_buf);
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Object detection bounding boxes:\r\n");
if (bb.value == 0) {
continue;
ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#else
ei_printf("Predictions:\r\n");
ei_printf(" %s: ", ei_classifier_inferencing_categories[i]);
ei_printf("%.5f\r\n", result.classification[i].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY
ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
ei_printf("Visual anomalies:\r\n");
for (uint32_t i = 0; i < result.visual_ad_count; i++) {
ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
continue;
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#endif
free(snapshot_buf);
* @brief Setup image sensor & start streaming
* @retval false if initialisation failed
bool ei_camera_init(void) {
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
//initialize the camera
if (err != ESP_OK) {
return false;
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
s->set_vflip(s, 1);
s->set_awb_gain(s, 1);
#endif
is_initialised = true;
return true;
* @brief Stop streaming of sensor data
void ei_camera_deinit(void) {
//deinitialize the camera
if (err != ESP_OK)
ei_printf("Camera deinit failed\n");
return;
return;
* @brief Capture, rescale and crop image
* @param[in] img_width width of output image
* @param[in] img_height height of output image
* @param[in] out_buf pointer to store output image, NULL may be used
* if ei_camera_frame_buffer is to be used for capture and resize/cropping.
* @retval false if not initialised, image captured, rescaled or cropped failed
bool do_resize = false;
if (!is_initialised) {
return false;
if (!fb) {
return false;
esp_camera_fb_return(fb);
if(!converted){
ei_printf("Conversion failed\n");
return false;
do_resize = true;
if (do_resize) {
out_buf,
EI_CAMERA_RAW_FRAME_BUFFER_COLS,
out_buf,
img_width,
img_height);
return true;
size_t pixel_ix = offset * 3;
size_t pixels_left = length;
size_t out_ptr_ix = 0;
while (pixels_left != 0) {
// Swap BGR to RGB here
// due to https://github.com/espressif/esp32-camera/issues/379
out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
// go to the next pixel
out_ptr_ix++;
pixel_ix+=3;
pixels_left--;
// and done!
return 0;
#endif
Currently using FOMO based on MobileNetV2 0.35
Thank you!
