Compiling for Teensy 4.1
I’'m running into a problem with compiling my Edge Impulse model for the Teensy 4.1. It is running file on the Arduino Nano 33 BLE Sense.
This is the error I get:
In file included from src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_compiler.h:54:0,
             from src/edge-impulse-sdk/CMSIS/DSP/Include/arm_math.h:382,
             from src/edge-impulse-sdk/dsp/spectral/../numpy.hpp:37,
             from src/edge-impulse-sdk/dsp/spectral/processing.hpp:28,
             from src/edge-impulse-sdk/dsp/spectral/spectral.hpp:27,
             from src\edge-impulse-sdk/classifier/ei_run_dsp.h:27,
             from src\edge-impulse-sdk/classifier/ei_run_classifier.h:30,
             from src\main.cpp:6:
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:196:44: error: macro "__enable_irq" passed 1 arguments, but takes just 0
 __STATIC_FORCEINLINE void __enable_irq(void)
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:207:45: error: macro "__disable_irq" passed 1 arguments, but takes just 0
 __STATIC_FORCEINLINE void __disable_irq(void)
Compiling .pio\build\teensy41\FrameworkArduino\usb_serial3.c.o
Compiling .pio\build\teensy41\FrameworkArduino\usb_touch.c.o
Compiling .pio\build\teensy41\FrameworkArduino\yield.cpp.o
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:196:27: error: variable or field '__enable_irq' declared void
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:41:50: error: expected primary-expression before '__asm'
   #define __ASM                                  __asm
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:198:3: note: in expansion of macro '__ASM'
   __ASM volatile ("cpsie i" : : : "memory");
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:41:50: error: expected '}' before '__asm'
   #define __ASM                                  __asm
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:207:27: error: variable or field '__disable_irq' declared void
   #define __ASM                                  __asm
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:209:3: note: in expansion of macro '__ASM'
   __ASM volatile ("cpsid i" : : : "memory");
   #define __ASM                                  __asm
src/edge-impulse-sdk/CMSIS/Core/Include/cmsis_gcc.h:210:1: error: expected declaration before '}' token
Can someone help me out with this?
Hi @Jurg, looks like another version cmsis_gcc.h is already in your build path. Are you building with the Arduino IDE using the Teensyduino extension?
Building works for me on Arduino 1.8.13 / Teensy 4.1
Ok, deploying a new model results in similar issues you are experiencing. Our SDK depends on the math functions in cmsis_gcc.h where also functions for enabling / disabling the interrupts are declared. The Teensy has declared those functions as macro inside the processor header file (imxrt.h).
A quick fix would be to check if the macro already exist in cmsis_gcc.h like:
  \brief   Enable IRQ Interrupts
  \details Enables IRQ interrupts by clearing the I-bit in the CPSR.
           Can only be executed in Privileged modes.
#ifndef __enable_irq
#endif
  \brief   Disable IRQ Interrupts
  \details Disables IRQ interrupts by setting the I-bit in the CPSR.
#ifndef __disable_irq
#endif
You can find the file in the extracted library folder: src/edge-impulse-sdk/CMSIS/Core/Include/cmsis-gcc.h
The #ifndef's dit it for me. My code only compiled on an hourly build of the Arduino IDE (1.8.14), (The filename or extension is too long on IDE 1.8.13). Thank you so much for helping me out!
@Jurg thanks for reporting back, we’re evaluating a patch in the SDK to deal with this, so you don’t have to patch your core - just need to make sure this does not have any unintended consequences on other dev boards.
