I have generated a C++ portable library (for keyword spotting) to be used with an esp32-devkit-c board. But, during compiling the espressif project I am getting an error include header error for the file “machine/_default_types.h”.
Model is for keyword spotting. Generated a portable C++ lib (float32 type)
- Trying to compile, error…
Want to compile this and run live classification test on the device. Should I go for any other type of deployment. The board I am using, esp32-s3-devkit-c, is not supported by default.
Compiler error. Cannot find the file #include <machine/_default_types.h>
- [X] Always
- [ ] Sometimes
- [ ] Rarely
Platform: ESP-32-S3-Devkit-C
Build Environment Details: Espressif IDF
OS Version: Windows 11
Edge Impulse Version (Firmware): 1.71.8 (library deployment)
Edge Impulse CLI Version: Not installed. Is this needed for lib deployment?
Project Version: ??
