Compilation error in Arduino IDE
While coding my Wio Terminal in Arduino IDE, I get this error message
This error occurred when I used the built Arduino library from deployment recently
“#include <new_inferencing.h>”
Previously I had no problem with the previous file
error message:
c:/users/123/appdata/local/arduino15/packages/seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe: error: C:\Users\123\AppData\Local\Temp\arduino\sketches\62E5AB56F4F958123B647FB675E44D6F\libraries\wio_anomaly_detection1_inferencing\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\objs.a(esp_nn_relu_s8_esp32s3.S.o): Conflicting CPU architectures 13/0
Please provide a solution
Hi @TianPutra,
My guess is that you previously tried to compile the wio_anomaly_detection1_inferencing library for another microcontroller target, and Arduino cached the compiled object (.o) files. For whatever reason, Arduino didn’t clean those out before trying to recompile. There’s no equivalent to “make clean” in Arduino. You can try switching boards and compiling again (Can I force the Arduino IDE to recompile everything? - IDE 2.x - Arduino Forum).
If you run into the same error again, I recommend deleting the wio_anomaly_detection1_inferencing in your libraries/ directory, re-importing the downloaded Edge Impulse library, and trying to compile again. That should effectively clean out all the old .o files.
I have the same problem. The EdgeImpulse project, which is generated this week, gives out ld error. The very same project didn’t get this kind of error before.
I have tried your advice, but the ld error remains.
Hi, TianPutra, I finally solved the problem by deleting all the files in the ESP-NN folder. It’s caused by compling and linking the assembly code in ESP-NN, maybe there are better solutions, e.g., changing the makefiles not to link these files, but I didn’t get a way to do this in Arduino IDE.
Hi, @denton and @TianPutra !
It does sound like there is an issue with ESP NN assembly files, that were added recently. The content of these files is behind macro guard already
#if EI_CLASSIFIER_TFLITE_ENABLE_ESP_NN && EI_CLASSIFIER_TFLITE_ENABLE_ESP_NN_S3
so it definitely should NOT be compiled in other boards. We have CI tests for Arduino boards and these do not show any issue. I’ll try to reproduce the issue manually now.
Meanwhile, which board do you use @denton ?
Yeah, you are right, but it was compiled on my ‘Wio Terminal’ board, with the macro guard being skipped.
Not really. I don’t think the macros were being skipped. More likely culprit is very old build tools used by Wio Terminal, which misinterpret an empty .S file as unknown CPU architecture. This does not happen for other comparable boards, using newer ARM build tools in Arduino IDE (e.g. Arduino Nano BLE33). We published a workaround in our documentation and will contact Seeed studio to ask to fix the issue on their side by updating build tools.
Okay. My problem has been resolved by deleting all the files in the ESP-NN folder. Thank you to all of you
Heads-up: the issue was fixed and the fix will be soon deployed to production.
Everyone, I followed your suggestions and strategies, but my code is still throwing errors. The development board I’m using is also the Wio Terminal.
On one hand, I cleared the path of the sketch mentioned in the error:
On the other hand, I have also deleted the entire ESP-NN folder inside the model file:
Does anyone have any other suggestions, please? Below is my code.
// Memory optimization: Remove this macro to save 10K RAM if target has limited memory
#define EIDSP_QUANTIZE_FILTERBANK   0
// Edge Impulse inference library - contains the trained AI model
#include <audio_RPW_larva_MFE_inferencing.h>
// Pin configuration for analog sound sensor
#define SoundPin A0
 * Data structure for audio inference management
 * This struct holds all necessary data for audio sampling and processing
typedef struct {
    int16_t *buffer;        // Pointer to audio sample buffer (16-bit signed integers)
    uint8_t buf_ready;      // Flag indicating if buffer is ready for processing (0/1)
    uint32_t buf_count;     // Current number of samples in buffer
    uint32_t n_samples;     // Total number of samples needed for inference
} inference_t;
// Global inference data structure instance
static inference_t inference;
// Static buffer for audio samples (alternative buffer, currently unused in this code)
static signed short sampleBuffer[2048];
// Calculate sampling period in microseconds for 16kHz sampling rate
// Formula: (600000 * (1.0 / desired_sample_rate)) = microseconds per sample
unsigned int sampling_period_us = round(600000 * (1.0 / 16000));
// Debug flag - set to true to see detailed neural network processing info
static bool debug_nn = false;
 * @brief      Arduino setup function - runs once at startup
 * Initializes serial communication, displays model information,
 * and sets up the audio sampling system for inference.
void setup()
    // Initialize serial communication at 115200 baud rate for debugging output
    Serial.begin(115200);
    // Print welcome message
    // Display comprehensive model information and settings
    ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    // Initialize the microphone inference system
    // EI_CLASSIFIER_RAW_SAMPLE_COUNT defines how many samples are needed
    if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
        ei_printf("ERR: Failed to setup audio sampling\r\n");
        return;
 * @brief      Arduino main loop function - runs continuously
 * This function performs the complete audio classification workflow:
 * 1. Records audio samples from the analog sensor
 * 2. Runs the Edge Impulse classifier on the audio data
 * 3. Displays classification results with confidence scores
 * 4. Repeats the process continuously
void loop()
    // Notify user that audio recording is starting
    ei_printf("Recording...\n");
    // Capture audio samples from the microphone/sound sensor
    if (!m) {
        return;
    // Notify user that recording is complete
    ei_printf("Recording done\n");
    // Prepare signal structure for Edge Impulse classifier
    signal_t signal;
    signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;  // Total number of samples
    signal.get_data = &microphone_audio_signal_get_data;   // Function to retrieve audio data
    // Initialize result structure to store classification output
    // Run the Edge Impulse classifier on the recorded audio
    // debug_nn parameter controls whether to show detailed processing info
    EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        return;
    // Display classification results with timing information
    ei_printf("Predictions ");
    ei_printf(": \n");
    // Print confidence scores for each classification label
        ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
    // If anomaly detection is enabled in the model, display anomaly score
#endif
 * @brief      Custom printf function for Edge Impulse library
 * This function provides formatted output similar to standard printf,
 * but routes the output through Arduino's Serial interface.
 * @param[in]  format     Printf-style format string
 * @param[in]  ...        Variable arguments matching the format string
    // Static buffer to hold formatted string (1KB max)
    // Handle variable arguments using standard library functions
    va_list args;
    va_start(args, format);
    // Format the string into the buffer
    va_end(args);
    // Output the formatted string via Serial if formatting was successful
    if (r > 0) {
        Serial.write(print_buf);
 * @brief      Initialize inference system and audio sampling setup
 * This function allocates memory for the audio buffer and initializes
 * the inference structure with the required parameters. It also configures
 * the analog pin for reading audio data.
 * @param[in]  n_samples  Number of audio samples needed for inference
 * @return     true if initialization successful, false if memory allocation fails
    // Allocate memory for audio sample buffer (16-bit integers)
    inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
    // Check if memory allocation was successful
    if(inference.buffer == NULL) {
        return false;
    // Initialize inference structure parameters
    inference.buf_count  = 0;        // Start with empty buffer
    inference.n_samples  = n_samples; // Store required sample count
    inference.buf_ready  = 0;        // Buffer not ready initially
    // Configure the sound sensor pin as analog input
    pinMode(SoundPin, INPUT);
    return true;
 * @brief      Record audio samples from analog sensor
 * This function captures audio data by reading from the analog sound sensor
 * at a controlled sampling rate. It converts the 10-bit ADC values (0-1023)
 * to 16-bit signed integers (-32768 to 32767) for audio processing.
 * @return     Always returns true when recording cycle completes
    // Reset buffer state for new recording
    // Record audio samples if buffer is not ready
    if (inference.buf_ready == 0) {
        // Sample loop - collect up to 8001 samples or until buffer is full
        for(int i = 0; i < 8001; i++) {
            // Read analog value from sound sensor and convert to 16-bit signed
            // map() converts 10-bit ADC (0-1023) to 16-bit audio range (-32768 to 32767)
            inference.buffer[inference.buf_count++] = map(analogRead(SoundPin), 0, 1023, -32768, 32767);
            // Wait for the calculated sampling period to maintain 16kHz sampling rate
            delayMicroseconds(sampling_period_us);
            // Check if we have collected enough samples for inference
            if(inference.buf_count >= inference.n_samples) {
                inference.buf_count = 0;    // Reset counter
                inference.buf_ready = 1;    // Mark buffer as ready
                break;                      // Exit sampling loop
    return true;
 * @brief      Retrieve and convert audio signal data for Edge Impulse processing
 * This callback function is used by the Edge Impulse classifier to access
 * the recorded audio data. It converts 16-bit integer samples to floating
 * point format as required by the neural network.
 * @param[in]  offset   Starting position in the audio buffer
 * @param[in]  length   Number of samples to retrieve
 * @param[out] out_ptr  Pointer to output buffer for float data
 * @return     0 on success
    // Convert 16-bit integer audio samples to float format
    // This uses Edge Impulse's numpy-style conversion function
    numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
    return 0;
 * @brief      Clean up inference system and release memory
 * This function should be called when audio inference is no longer needed.
 * It frees the dynamically allocated audio buffer to prevent memory leaks.
 * Note: This function is defined but not currently called in the main loop.
static void microphone_inference_end(void)
    // Free the dynamically allocated audio buffer
    free(inference.buffer);
// Compile-time check to ensure the Edge Impulse model was trained for microphone/audio data
// This preprocessor directive will cause a compilation error if the wrong model type is used
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor. This code requires a microphone-trained Edge Impulse model."
#endif
