Camera failed to capture image and camera not initialized
After uploading and trying to start the edge impulse pre-made code on object detection it says “camera failed to capture image and camera not initialize”
I followed the DroneBot Workshop tutorial to a whim and it still says tgat
in serial monitor for it to say what the camera sees or like, detect the object I put in front of it
ERR: Camera is not initialized
Failed to capture image e
  • [ ] Always
  • Platform: ESP32-CAM
  • Build Environment Details: FTDI Arduino ide 2.3.7
  • OS Version: windows 11
I don’t know what the problem at this point, because when I just try to capute image using the pre-made code for video streaming it works just fine
Did you enable the PSRAM on the ESP32 in the Arduino IDE? I ran into that same problem on my ESP32-S3 Sense board and it was solved by enabling the PSRAM.
I changes the format and it worked!
