Dear All, I am Lok and I had a Edge Impulse test program with below code, it support connect to ESP32-CAM and identify the object in front of camera is dog or cat.
The program works completely fine, however I would like to add support of TFT, on the TFT, I want to show the screen that camera captured.
After adding three include files in the heading (I installed all of three libraries)
#include <TJpg_Decoder.h>
#include <TFT_eSPI.h>
#include <ArduinoJson.h>
I still be able to write the program into ESP32-CAM but when the camera will not work.
I am wondering why adding three files in the heading will crash the program, it does not make any sense, I didn’t start my custom coding yet… Could someone please provide some solution for me? or perhaps let me know how come it happen…Thanks
This is the trained model.
[Download](https://drive.google.com/file/d/1nkZo5qPYqVxioG8f--xnCH_JUhg_Tjdk/view?usp=share_link)
The program works perfectly fine (Before adding the three include files in the heading).
* SOFTWARE.
#include <as1234-project-1_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
.pin_pwdn = PWDN_GPIO_NUM,
.pin_reset = RESET_GPIO_NUM,
.pin_xclk = XCLK_GPIO_NUM,
.pin_d7 = Y9_GPIO_NUM,
.pin_d6 = Y8_GPIO_NUM,
.pin_d5 = Y7_GPIO_NUM,
.pin_d4 = Y6_GPIO_NUM,
.pin_d3 = Y5_GPIO_NUM,
.pin_d2 = Y4_GPIO_NUM,
.pin_d1 = Y3_GPIO_NUM,
.pin_d0 = Y2_GPIO_NUM,
.pin_vsync = VSYNC_GPIO_NUM,
.pin_href = HREF_GPIO_NUM,
.pin_pclk = PCLK_GPIO_NUM,
.xclk_freq_hz = 20000000,
.ledc_timer = LEDC_TIMER_0,
.frame_size = FRAMESIZE_QVGA, //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
.fb_count = 1, //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
void setup()
Serial.begin(115200);
while (!Serial);
else {
ei_sleep(2000);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
void loop()
return;
if(snapshot_buf == nullptr) {
return;
ei::signal_t signal;
free(snapshot_buf);
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
if (bb.value == 0) {
continue;
ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
if (!bb_found) {
ei_printf(" No objects found\n");
#else
ei_printf(" %s: %.5f\n", result.classification[ix].label,
#endif
#endif
free(snapshot_buf);
* @brief Setup image sensor & start streaming
* @retval false if initialisation failed
bool ei_camera_init(void) {
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
//initialize the camera
if (err != ESP_OK) {
return false;
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
s->set_vflip(s, 1);
s->set_awb_gain(s, 1);
#endif
is_initialised = true;
return true;
* @brief Stop streaming of sensor data
void ei_camera_deinit(void) {
//deinitialize the camera
if (err != ESP_OK)
ei_printf("Camera deinit failed\n");
return;
return;
* @brief Capture, rescale and crop image
* @param[in] img_width width of output image
* @param[in] img_height height of output image
* @param[in] out_buf pointer to store output image, NULL may be used
* if ei_camera_frame_buffer is to be used for capture and resize/cropping.
* @retval false if not initialised, image captured, rescaled or cropped failed
bool do_resize = false;
if (!is_initialised) {
return false;
if (!fb) {
return false;
esp_camera_fb_return(fb);
if(!converted){
ei_printf("Conversion failed\n");
return false;
do_resize = true;
if (do_resize) {
out_buf,
EI_CAMERA_RAW_FRAME_BUFFER_COLS,
out_buf,
img_width,
img_height);
return true;
size_t pixel_ix = offset * 3;
size_t pixels_left = length;
size_t out_ptr_ix = 0;
while (pixels_left != 0) {
out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix + 2];
// go to the next pixel
out_ptr_ix++;
pixel_ix+=3;
pixels_left--;
// and done!
return 0;
#endif
This is the normal output.
Predictions (DSP: 3 ms., Classification: 1034 ms., Anomaly: 0 ms.):
Cat: 0.87500
Dog: 0.12500
Cat: 0.87500
Dog: 0.12500
Cat: 0.88281
Dog: 0.11719
Cat: 0.79688
Dog: 0.20312
After three include files are added, the camera will crash itself, here are the Serial Monitor output.
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13924
ho 0 tail 12 room 4
load:0x40080400,len:3600
entry 0x400805f0
Camera initialized
Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x03cd1e22 PS : 0x00060830 A0 : 0x800d6ccd A1 : 0x3ffb1fb0
A2 : 0x400e695c A3 : 0x3ffc5bf0 A4 : 0x00000001 A5 : 0x3ffb20d8
A6 : 0x00060820 A7 : 0x00000008 A8 : 0x800e697e A9 : 0x88f4ac63
A10 : 0x90052292 A11 : 0x88f4ac63 A12 : 0x3ffc5bf0 A13 : 0x00000001
A14 : 0x3ffb8ef0 A15 : 0x00000000 SAR : 0x00000011 EXCCAUSE: 0x00000014
EXCVADDR: 0x03cd1e20 LBEG : 0x40087e2e LEND : 0x40087e39 LCOUNT : 0x00000000
Backtrace: 0x03cd1e1f:0x3ffb1fb0 0x400d6cca:0x3ffb1fe0 0x400e69d9:0x3ffb2020 0x400e685d:0x3ffb20f0 0x400d2932:0x3ffb2130 0x400d34f7:0x3ffb2150 0x400da711:0x3ffb2290
ELF file SHA256: 5ef126082072da89
