I trained my model on the website for pattern recognition. After training, I downloaded C++ library of my model locally on my my computer. I get a zip file with all the information.I also cloned one more repo example-edge-inference library from c++ standalone_c++_example. I took the contents from the zip file downloaded from my laptop and merged it with standalone example. I followed the tutorials step by step as mentioned on website. Works perfectly well on my laptop.
Then using scp protocol I transferred it folder to rpi 4.
i could build my model on rpi using this command
$ APP_CAMERA=1 make -j
However, when I use this command to build on rpi , I get an error.
$ APP_CAMERA=1 TARGET_LINUX_X86=1 USE_FULL_TFLITE=1 make -j
The error is
Hi @prarthana
This command issued on RPi4:
Mean you are going to cross-compile the app for x86 CPU (for example, your laptop). The correct command is:
APP_CAMERA=1 TARGET_LINUX_AARCH64=1 USE_FULL_TFLITE=1 make -j
Also, make sure you have the OpenCV library installed. You can do it using the system package manager or use the script from our repository.
Best regards,
Mateusz
that was my typo while asking the question. I am sorry about it. However, I used the correct flag for my rpi architecture i.e APP_CAMERA=1 TARGET_LINUX_AARCH64=1 USE_FULL_TFLITE=1 make -j.
Thanks prarthana sigedar
Hi @prarthana
Did it solve your question? Or the last command you posted is still making an issue?
Kind regards,
Mateusz
this is still the issue @Mateusz.
I am also getting this error when I try to use hardware acceleration
Hi @prarthana
The error says:
Cannot use full TensorFlow Lite with EON
It looks like you exported EON Compiled C++ model, so you cannot compile the app with USE_FULL_TFLITE=1.
Best regards,
Mateusz
Is there any way around such that I can export a compiled model without EON and then use TF_LITE?
If yes? Then how?
I am trying all the ways to improve the FPS on rpi4. Currently, when I integrate the fomo classification with my code, I get around 15 fps on rpi. However, when I only run the compiled code for classification without integration with my code, then I get an fps around 30.
I am not able to get this discrepancy so I was trying to use hardware acceleration for rpi4
Thankyou
Hi @prarthana I’m attempting the same and have reproduced this issue. Have you figured out how to achieve hardware acceleration yet?
@prarthana I figured it out … there is a switch on the build page that toggles whether to enable EON or not. Turn it off and you’ll be able to compile.
Thanks a lot. I will look into it and get back.
Hello @inteladata
I turned off the eon compiler, and first I ran it on the computer by running the command for hardware acceleration i.e is$ APP_CAMERA=1 TARGET_LINUX_X86=1 USE_FULL_TFLITE=1 make -j.
It solved the error which I was getting previously. However, the inference speed dropped from 30ms to approx 300ms on laptop. There was a huge discrepancy in the inference speed. I could not understand the reason behind it.
Thanks,
Prarthana Sigedar
