Versioning was introduced Sept 2020
@jenny @louis @shawn_edgeimpulse
As far as I remember versioning worked great, allows you to make a new model based on an old version. Recently I wanted to keep my old model and make a duplicate, so I made a verison and it worked fine, but did not save the data. No problem for me since I had the original; I exported then imported the data, but that doesn’t seem to be correct ability for versioning. The verison should save the data as well as the model structure.
Today I loaded an old: sound, classify and fomo model and made a version and then restored the version and for each each case in “developer” mode the new version did not have any data!
Can someone check my results, and is this correct for the developer mode. Makes sense that full versioning with data is only a paid ability, but it should mention that somewhere.
