Thank you for the response, as suggested , heres the output for the gstreamer command
(wasnt able to attach the file so heres the text copy pasted)
Probing devicesā¦
[0:04:17.701406191] [1908] INFO Camera camera_manager.cpp:327 libcamera v0.4.0
Device found:
class : Source/Video
caps : image/jpeg, width=160, height=120
image/jpeg, width=176, height=144
image/jpeg, width=320, height=176
image/jpeg, width=320, height=240
image/jpeg, width=352, height=288
image/jpeg, width=432, height=240
image/jpeg, width=544, height=288
image/jpeg, width=640, height=360
image/jpeg, width=640, height=480
image/jpeg, width=752, height=416
image/jpeg, width=800, height=448
image/jpeg, width=864, height=480
image/jpeg, width=800, height=600
image/jpeg, width=960, height=544
image/jpeg, width=1024, height=576
image/jpeg, width=960, height=720
image/jpeg, width=1184, height=656
image/jpeg, width=1280, height=720
image/jpeg, width=1280, height=960
video/x-raw, format=YUY2, width=160, height=120
video/x-raw, format=YUY2, width=176, height=144
video/x-raw, format=YUY2, width=320, height=176
video/x-raw, format=YUY2, width=320, height=240
video/x-raw, format=YUY2, width=352, height=288
video/x-raw, format=YUY2, width=432, height=240
video/x-raw, format=YUY2, width=544, height=288
video/x-raw, format=YUY2, width=640, height=360
video/x-raw, format=YUY2, width=640, height=480
video/x-raw, format=YUY2, width=752, height=416
video/x-raw, format=YUY2, width=800, height=448
video/x-raw, format=YUY2, width=864, height=480
video/x-raw, format=YUY2, width=800, height=600
video/x-raw, format=YUY2, width=960, height=544
video/x-raw, format=YUY2, width=1024, height=576
video/x-raw, format=YUY2, width=960, height=720
video/x-raw, format=YUY2, width=1184, height=656
video/x-raw, format=YUY2, width=1280, height=720
video/x-raw, format=YUY2, width=1280, height=960
gst-launch-1.0 libcamerasrc camera-name="/base/soc\@0/usb\@4ef8800/usb\@4e00000-1.3:1.0-046d:0825" ! ...
Device found:
name : Monitor of Dummy Output
class : Audio/Source
caps : audio/x-raw, format={ (string)S16LE, (string)S16BE, (string)F32LE, (string)F32BE, (string)S32LE, (string)S32BE, (string)S24LE, (string)S24BE, (string)S24_32LE, (string)S24_32BE, (string)U8 }, layout=interleaved, rate=[ 1, 768000 ], channels=[ 1, 32 ]
audio/x-alaw, rate=[ 1, 768000 ], channels=[ 1, 32 ]
audio/x-mulaw, rate=[ 1, 768000 ], channels=[ 1, 32 ]
properties:
node.name = auto_null
device.description = Dummy Output
audio.rate = 48000
audio.channels = 2
audio.position = FL,FR
media.class = Audio/Sink
factory.name = support.null-audio-sink
node.virtual = true
monitor.channel-volumes = true
factory.id = 19
clock.quantum-limit = 8192
client.id = 33
node.driver = true
port.group = stream.0
node.loop.name = data-loop.0
library.name = audioconvert/libspa-audioconvert
object.id = 35
object.serial = 35
device.class = monitor
is-default = false
gst-launch-1.0 pulsesrc device=auto_null.monitor ! ...
Device found:
name : Webcam C270 Mono
properties:
alsa.card = 0
alsa.card_name = USB Device 0x46d:0x825
alsa.class = generic
alsa.components = USB046d:0825
alsa.device = 0
alsa.driver_name = snd_usb_audio
alsa.id = USB Audio
alsa.long_card_name = USB Device 0x46d:0x825 at usb-xhci-hcd.2.auto-1.3, high speed
alsa.mixer_name = USB Mixer
alsa.name = USB Audio
alsa.resolution_bits = 16
alsa.subclass = generic-mix
alsa.subdevice = 0
alsa.subdevice_name = subdevice #0
alsa.sync.id = 00000000:00000000:00000000:00000000
api.alsa.card.longname = USB Device 0x46d:0x825 at usb-xhci-hcd.2.auto-1.3, high speed
api.alsa.card.name = USB Device 0x46d:0x825
api.alsa.path = hw:0
api.alsa.pcm.card = 0
api.alsa.pcm.stream = capture
audio.channels = 1
audio.position = MONO
card.profile.device = 1
device.api = alsa
device.class = sound
device.icon_name = audio-card-analog
device.id = 59
device.profile.description = Mono
device.profile.name = mono-fallback
device.routes = 1
factory.name = api.alsa.pcm.source
media.class = Audio/Source
device.description = Webcam C270
node.name = alsa_input.usb-046d_0825_404948D0-02.mono-fallback
node.nick = USB Device 0x46d 0x825
node.pause-on-idle = false
object.path = alsa:acp:U0x46d0x825:1:capture
port.group = capture
priority.driver = 2000
priority.session = 2000
factory.id = 19
client.id = 47
node.driver = true
object.id = 53
object.serial = 65
api.acp.auto-port = false
api.acp.auto-profile = false
api.alsa.card = 0
api.alsa.split-enable = true
api.alsa.use-acp = true
api.dbus.ReserveDevice1 = Audio0
api.dbus.ReserveDevice1.Priority = -20
device.bus = usb
device.bus-id = usb-046d_0825_404948D0-02
device.bus_path = platform-xhci-hcd.2.auto-usb-0:1.3:1.2
device.enum.api = udev
device.form_factor = webcam
device.name = alsa_card.usb-046d_0825_404948D0-02
device.nick = USB Device 0x46d:0x825
device.plugged.usec = 117075077
device.product.id = 0x0825
device.product.name = Webcam C270
device.serial = 046d_0825_404948D0
device.subsystem = sound
sysfs.path = /devices/platform/soc@0/4ef8800.usb/4e00000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3:1.2/sound/card0
device.vendor.id = 0x046d
device.vendor.name = Logitech, Inc.
spa.object.id = 2
device.string = 0
is-default = true
gst-launch-1.0 pulsesrc device=alsa_input.usb-046d_0825_404948D0-02.mono-fallback ! ...
Device found:
class : Audio/Sink
properties:
audio.rate = 48000
audio.channels = 2
node.virtual = true
factory.id = 19
client.id = 33
node.driver = true
object.id = 35
object.serial = 35
is-default = true
gst-launch-1.0 ... ! pulsesink device=auto_null
Device found:
name : llvmpipe (LLVM 19.1.7, 128 bits)
class : Video/Sink
caps : video/x-raw(memory:VulkanImage)
properties:
vulkan.name = llvmpipe (LLVM 19.1.7, 128 bits)
vulkan.type = CPU
vulkan.api.version = 1.4.318
vulkan.api.version.major = 1 (0x00000001)
vulkan.api.version.minor = 4 (0x00000004)
vulkan.api.version.patch = 318 (0x0000013e)
vulkan.driver.version = 25.2.3
vulkan.driver.version.major = 25 (0x00000019)
vulkan.driver.version.minor = 2 (0x00000002)
vulkan.driver.version.patch = 3 (0x00000003)
vulkan.vendor.id = 65541 (0x00010005)
vulkan.device.id = 0 (0x00000000)
vulkan.memory.n_heaps = 1 (0x00000001)
vulkan.memory.heaps.0.size = 1825193984
vulkan.memory.heaps.0.flags = 1 (0x00000001)
vulkan.memory.heaps.0.flags.str = device-local
vulkan.memory.n_types = 1 (0x00000001)
vulkan.memory.types.0.heap = 0 (0x00000000)
vulkan.memory.types.0.flags = 15 (0x0000000f)
vulkan.memory.types.0.flags.str = device-local|host-visible|host-coherent|host-cached
vulkan.n_queue_families = 1 (0x00000001)
vulkan.queue_family.0.n_queues = 1 (0x00000001)
vulkan.queue_family.0.flags = 15 (0x0000000f)
vulkan.queue_family.0.flags.str = graphics|compute|transfer|sparse-binding
vulkan.queue_family.0.timestamp_resolution = 64 (0x00000040)
vulkan.queue_family.0.min_image_transfer_granuality.width = 1 (0x00000001)
vulkan.queue_family.0.min_image_transfer_granuality.height = 1 (0x00000001)
vulkan.queue_family.0.min_image_transfer_granuality.depth = 1 (0x00000001)
is-default = false
gst-launch-1.0 ... ! vulkansink
Device found:
name : Turnip Adreno (TM) 702
class : Video/Sink
properties:
vulkan.name = Turnip Adreno (TM) 702
vulkan.type = integrated
vulkan.api.version = 1.0.318
vulkan.api.version.minor = 0 (0x00000000)
vulkan.vendor.id = 20803 (0x00005143)
vulkan.device.id = 117441024 (0x07000200)
vulkan.memory.heaps.0.size = 912596992
vulkan.memory.n_types = 2 (0x00000002)
vulkan.memory.types.0.flags = 7 (0x00000007)
vulkan.memory.types.1.heap = 0 (0x00000000)
vulkan.memory.types.1.flags = 11 (0x0000000b)
vulkan.memory.types.1.flags.str = device-local|host-visible|host-cached
vulkan.queue_family.0.flags = 7 (0x00000007)
vulkan.queue_family.0.timestamp_resolution = 48 (0x00000030)
is-default = true
