Arduino Nano 33 BLE Sense rev2 acquisitions are empty
Data acquisitions are empty.
Are all Arduino Nano 33 BLE Sense rev2’s sensors broken?
Wrong firmware?
[553528]
  1. downloaded https://cdn.edgeimpulse.com/firmware/arduino-nano-33-ble-sense.zip
  2. updated the fw following Arduino Nano 33 BLE Sense | Edge Impulse Documentation
  3. executed flash_windows.bat
  4. executed edge-impulse-daemon
  5. Once connected the device to the project, start acquisition (accelerometer + gyro), but the behavior with microphone is the same)
  6. Once data upload completed, the page shows all signals at 0 (see attached image)
accZ cant’t be all 0
  • [x] Always
Data acquisistion cli
  path: '/api/training/data',
  label: 'Idle',
  length: 2000,
  interval: 10,
  hmacKey: '7c4d21654374e7c419d101b0f074cda9',
  sensor: 'Inertial (Accelerometer / Gyroscope)'
[SER] Configured upload settings
[SER] Sampling started
[SER] Sampling done
[SER] Device not connected to WiFi directly, reading from buffer (bytes 0 - 19364, expecting to read ~25818 bytes...
[SER] Reading 35% complete...
[SER] Reading 75% complete...
[SER] Reading from buffer OK
[SER] File is 19364 bytes after decoding
[SER] Uploading to https://ingestion.edgeimpulse.com/api/training/data
[SER] Uploading to https://ingestion.edgeimpulse.com/api/training/data OK
fw update
C:\arduino-nano-33-ble-sense>flash_windows.bat
You're using an untested version of Arduino CLI, this might cause issues (found: 1.1.0, expected: 0.33.x
Finding Arduino Mbed core...
Installing Arduino Mbed core...
Sto scaricando l'indice: package_index.tar.bz2 scaricato
Sto scaricando i pacchetti...
arduino:arm-none-eabi-gcc@7-2017q4 scaricato
arduino:bossac@1.9.1-arduino2 scaricato
arduino:dfu-util@0.10.0-arduino1 scaricato
arduino:openocd@0.11.0-arduino2 scaricato
arduino:rp2040tools@1.0.6 scaricato
arduino:mbed_nano@4.0.2 scaricato
Installazione arduino:arm-none-eabi-gcc@7-2017q4...
Strumento di configurazione....
arduino:arm-none-eabi-gcc@7-2017q4 installato
Installazione arduino:bossac@1.9.1-arduino2...
arduino:bossac@1.9.1-arduino2 installato
Installazione arduino:dfu-util@0.10.0-arduino1...
arduino:dfu-util@0.10.0-arduino1 installato
Installazione arduino:openocd@0.11.0-arduino2...
arduino:openocd@0.11.0-arduino2 installato
Installazione arduino:rp2040tools@1.0.6...
arduino:rp2040tools@1.0.6 installato
Sto installando la piattaforma arduino:mbed_nano@4.0.2...
Configurazione della piattaforma....
La piattaforma arduino:mbed_nano@4.0.2 è installata
Installing Arduino Mbed core OK
Finding Arduino Mbed core OK
Finding Arduino Nano 33 BLE...
Finding Arduino Nano 33 BLE OK at COM5
arduino:mbed_nano 4.0.2      4.2.1  Arduino Mbed OS Nano Boards
Device       : nRF52840-QIAA
Version      : Arduino Bootloader (SAM-BA extended) 2.0 [Arduino:IKXYZ]
Address      : 0x0
Pages        : 256
Page Size    : 4096 bytes
Total Size   : 1024KB
Planes       : 1
Lock Regions : 0
Locked       : none
Security     : false
Erase flash
Hi @robertof
Is this in relation to the LSM9DS1 support query? I believe that sensor fusion for this rev2 will not work the same.
i am having a similar issue, all seems to be connected correctly to my esp32 and mpu6050, yet the data in edge impulse seems empty. any solutions found for this yet?
@Eoin I’m seeing other students still having this issue. Has there been any resolution or workarounds?
@Arjan can you help here do you know why users would not be able to collect data from the version 2 IMU when they have the latest firmware?
Checking withe the embedded team, it seems the firmware should support both, but if you are seeing users with the latest firmware experiencing isssues we need to check that out. I only have v1 here so can’t validate the v2.
Hi @robertof ,
I don’t see any issues on my end. Can you check the initialization step from the serial debug? With the firmware you linked I get following on my rev2 board:
OV7676x camera not attached or failed to init
Hello from Edge Impulse on Arduino Nano 33 BLE Sense
Compiled on Jan 22 2024 16:40:27
Failed to initialize ei_IMU for rev1!
IMU for rev2 initialized
Failed to initialize HTS!
HS300x initialized
BARO initialized
APDS initialized
