ADXL345 motion sensor compile failed
use adxl345 sensor to generate on/off signal, deployed as arduino library. when i integrate the library to seeedstudio XIAO-esp32s3 board. It fails to compile.
- use adxl345 to generate x,y,z data and upload 2 data sets(on and off) to edge impulse
- train
- deploy
Arduino ide compile correctly and can use the adxl345 to generate on and off signal
compile failed
- [X ] Always
- [ ] Sometimes
- [ ] Rarely
Platform: [Xiao-ESP32S3.]
Build Environment Details: Arduino IDE 2.3.2]
OS Version: [Windows 10]
Edge Impulse Version (Firmware):
#define EI_STUDIO_VERSION_MAJOR 1
#define EI_STUDIO_VERSION_MINOR 58
#define EI_STUDIO_VERSION_PATCH 0 -
Edge Impulse CLI Version:
Edge Impulse data forwarder v1.27.1 -
Project Version: [e.g., 1.0.0]
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp: In function ‘TfLiteStatus tflite::{anonymous}::Prepare(TfLiteContext*, TfLiteNode*)’:
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp:1789:67: error: either all initializer clauses should be designated or none of them should be
1789 | .channels = input->dims->data[3], 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp:1793:68: error: either all initializer clauses should be designated or none of them should be
1793 | .channels = output->dims->data[3], 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp:1795:80: error: either all initializer clauses should be designated or none of them should be
1795 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp: In function ‘void tflite::{anonymous}::EvalQuantizedPerChannel(TfLiteContext*, TfLiteNode*, const TfLiteConvParams&, const NodeData&, const TfLiteEvalTensor*, const TfLiteEvalTensor*, const TfLiteEvalTensor*, TfLiteEvalTensor*)’:
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp:1883:58: error: either all initializer clauses should be designated or none of them should be
1883 | .channels = input_depth, 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp:1887:59: error: either all initializer clauses should be designated or none of them should be
1887 | .channels = output_depth, 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\conv.cpp:1889:80: error: either all initializer clauses should be designated or none of them should be
1889 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp: In function ‘void tflite::{anonymous}::EvalQuantizedPerChannel(TfLiteContext*, TfLiteNode*, const TfLiteDepthwiseConvParams&, const NodeData&, const TfLiteEvalTensor*, const TfLiteEvalTensor*, const TfLiteEvalTensor*, TfLiteEvalTensor*)’:
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp:1727:58: error: either all initializer clauses should be designated or none of them should be
1727 | .channels = input_depth, 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp:1731:59: error: either all initializer clauses should be designated or none of them should be
1731 | .channels = output_depth, 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp:1733:80: error: either all initializer clauses should be designated or none of them should be
1733 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp: In function ‘TfLiteStatus tflite::{anonymous}::Prepare(TfLiteContext*, TfLiteNode*)’:
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp:1836:67: error: either all initializer clauses should be designated or none of them should be
1836 | .channels = input->dims->data[3], 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp:1840:68: error: either all initializer clauses should be designated or none of them should be
1840 | .channels = output->dims->data[3], 1
c:\Users\Emma\Documents\Arduino\libraries\imu_inferencing\src\edge-impulse-sdk\tensorflow\lite\micro\kernels\depthwise_conv.cpp:1842:80: error: either all initializer clauses should be designated or none of them should be
1842 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
exit status 1
arduino code: https://raw.githubusercontent.com/xyu6/edgeimpluse-motion/refs/heads/main/xiao%20esp32s3%20adxl345_sense_accelerometer.ino
