Hi everyone. I am using a macbook pro m1 and when I’m trying to install edge-impulse-daemon i get the error: zsh: command not found: edge-impulse-daemon.
Previously, I’ve installed node.js and following all the steps of the tutorial. I’ve also tried the solutions of a similar post here, but still get this error. Anyone can help?
Thanks in advance,
Ilias
Hi, have you have uninstalled and reinstalled edge-impulse-cli? with…
npm uninstall -g edge-impulse-cli
If that doesn’t work, you could also try the install scripts here: https://docs.edgeimpulse.com/docs/cli-installation#installation-script
Hi @jenny. I tried uninstall and reinstall edge-impulse-cli but i get this:
added 299 packages, and audited 300 packages in 19s
12 packages are looking for funding
run npm fund for details
10 vulnerabilities (5 moderate, 1 high, 4 critical)
To address issues that do not require attention, run:
npm audit fix
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
I have the same problem, I’m using Kali Linux.
Can you report the value of $PATH?
Another thing, if you followed this tutorial here: https://docs.edgeimpulse.com/docs/cli-installation
Can you replace .profile with .zprofile if zsh is also your login shell. Otherwise you can use your .zshrc to export the PATH as in the tutorial.
