Good morning,
I implemented a custom learning bloc and i pushed it to edge impulse.
i trained it and i get the following result with an error in the inference step. i cant also deploy it.
project id:532911 (impulse#13)
do you have any idea about that, please?
thanks an advance
Training model on 822 inputs…
Training model OK
Training model OK
Training model OK
Mean accuracy (testing set):
0.8053088803088801
Saving model…
0.8053088803088801
Saving model…
0.8053088803088801
Saving model…
Saving model OK
Saving model OK
Saving model…
Saving model OK
Saving model OK
Profiling model… Job scheduled at 24 Nov 2024 20:16:29 Job started at 24 Nov 2024 20:16:29 Job scheduled at 24 Nov 2024 20:16:29
[spinner-done] Job started at 24 Nov 2024 20:16:29
Loading data for profiling…
Loading data for profiling OK
Calculating performance metrics…
Calculating inferencing time…
Failed to calculate inferencing time: ERR: Could not open file /home/model.tflite
hi@brianmcfadden -
My custom code use resnet50 to get features .the output of resnet50 is used to train oneclasssvm. the generated model is .pkl (because oneclasssvm is sckitlearn lib).
Did you save the model to the default directory, e.g. save_saved_model(model, args.out_directory) ? . yes i saved it as .pkl model (with open(os.path.join(args.out_directory, ‘modelocsvm.pkl’),‘wb’)). i followed the Custom scikit-learn ML block example for Edge Impulse example to generate the .pkl model using docker.
do i have seperate the resnet50 and the oneclasssvm each one in each custom code?
thanks an advance
OK, so there are a few things going on here, @aydi. Thanks for clarifying what you are trying to do and that you are saving a .pkl file.
First, there is some history with the example-custom-ml-block-scikit repo. This example was originally developed before we did automatic .pkl to .tflite conversion and it demonstrated how to do this by using a JAX inference function. The repo has since been updated to leverage the automatic .pkl to .tflite conversion, yet that conversion only supports specific types of scikit-learn models. Beyond that, the supported models have been incorporated directly into the Edge Impulse platform (for Pro and Enterprise plan customers). The list of models can be found in Supported classical ML algorithms (however, I can see that doc needs an update as we support more algos now!).
Next, even if you are using a supported scikit-learn model, I think you will run into issues trying to stack a ResNet-50 model and scikit-learn model into a single learning block. One way to handle this is to use a custom processing block that produces the features using the ResNet-50 model and passes that to the scikit-learn model in the learning block. We have a Sensor fusion using embeddings tutorial that describes this process.
I’ve identified a couple items that need updating:
The example repo to describe the limitations with automatic .pkl to .tflite conversion
The list of supported classical ML models in our docs
hello @brianmcfadden
sorry to be late. because i tried to implement other algorithm using custom ml. One way to handle this is to use a custom processing block that produces the features using the ResNet-50 model and passes that to the scikit-learn model in the learning block.
i seperated the resnet50 and OCSVM into custom processing block (named resnet50in my project) and custom larning bloc (named ocsvm inmy project), respectively as you told me. but i get now this error.
Need data from at least two different labels to train a model. Add data with another label under “Data acquisition”. (i even tried to add some images of another class in train dataset the error did not change).
project ID:638253
thanks an advance
