Hi
I’m making a Voice Recognition project using Seeed XIAO BLE Sense (nRF52840). I’ve used Data Forwarding to get the audio data to Edge Impulse and it works just fine when i do the live classification.
When i use the Example present on the Arduino Library (nano_ble33_sense_microphone) it gets the results all wrong.
I’ve tried changing the PDM frequency and a bunch of other values or changing the board on the Board Manager and nothing worked.
Recently i noticed that i was using the Seeed nRF52 mbed-enabled Boards when i should be using Seeed nRF52 Boards but when i try to upload code it gives me this error:
Arduino: 1.8.19 (Windows 10), Board:“Seeed XIAO nRF52840 Sense, S140 7.3.0, Level 2 (Full Debug)”
c:/users/bmber/appdata/local/arduino15/packages/seeeduino/tools/arm-none-eabi-gcc/9-2019q4/bin/…/lib/gcc/arm-none-eabi/9.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe: sketch\objs.a(nano_ble33_sense_microphone.ino.cpp.o): in function `std::vector<unsigned long, std::allocator >::_M_range_check(unsigned int) const’:
c:\users\bmber\appdata\local\arduino15\packages\seeeduino\tools\arm-none-eabi-gcc\9-2019q4\arm-none-eabi\include\c++\9.2.1\bits/stl_vector.h:1070: undefined reference to `std::__throw_out_of_range_fmt(char const*, …)’
exit status 1
I used this code to data forward if it helps in any way:
#include <PDM.h>
short sampleBuffer[2048];
volatile int samplesRead = 0;
void setup() {
Serial.begin(115200);
while (!Serial);
PDM.onReceive(onPDMdata);
PDM.setBufferSize(2048);
if (!PDM.begin(1, 16000)) {
Serial.println(“Failed to start PDM!”);
while (1);
void loop() {
if (samplesRead) {
for (int i = 0; i < samplesRead; i++) {
Serial.println(sampleBuffer[i]);
samplesRead = 0;
void onPDMdata() {
int bytesAvailable = PDM.available();
PDM.read(sampleBuffer, bytesAvailable);
samplesRead = bytesAvailable / 2;
Anyone got this problem too?
