Question/Issue: Hi, I don’t understand why my YOLOv5 AI cannot train. The target device is OpenMV Cam H7 Plus. Below I write the training error:
Creating job… OK (ID: 21106135)
Scheduling job in cluster…
Container image pulled!
Job started
Job started
Transforming Edge Impulse data format into something compatible with YOLOv5
File “/usr/local/lib/python3.8/dist-packages/PIL/Image.py”, line 2813, in fromarray
mode, rawmode = _fromarray_typemap[typekey]
KeyError: ((1, 1, 1), ‘|u1’)
The above exception was the direct cause of the following exception:
File “extract_dataset.py”, line 80, in
convert(X=X_train, Y=Y_train, category=‘train’)
File “extract_dataset.py”, line 51, in convert
im = Image.fromarray(raw_img_data)
File “/usr/local/lib/python3.8/dist-packages/PIL/Image.py”, line 2815, in fromarray
raise TypeError(“Cannot handle this data type: %s, %s” % typekey) from e
TypeError: Cannot handle this data type: (1, 1, 1), |u1
Job failed (see above)
**Project ID:**423785
