Which kind of algorithm is used in Edge Impulse?
Hello @S.sarkar,
If you’re asking on the ML side, here are some info: Learning blocks - Edge Impulse Documentation
We also use different algorithm for the pre-processing part. You can have more info here: Processing blocks - Edge Impulse Documentation
You can find all the details you are seeking by clicking the 3 vertical dots on the top right of the Neural Network Setting frame and then selecteng Edit in Keras Mode.
