Hi, I am doing a thesis on object detection and I used the linear regression as learning block. One of my panelists required me to provide the full feature extraction step-by-step process. Can you guys help me out what features are extracted? Is it color, edge, etc… Thank you!
Hello @niwlyer,
Here you can have a look at how our pre-processing blocks work: https://github.com/edgeimpulse/processing-blocks
For the image pre-processing block, we are only using the number of channels and the size of the image as variables.
If you want to go further in the image pre-processing, I worte an article some time ago on how to add your own custom DSP block that works with images: https://www.edgeimpulse.com/blog/utilize-custom-processing-blocks-in-your-image-ml-pipelines
Note that it won’t work with our Object Detection pre-trained models but you can use this with a custom DL model.
Hi Louis,
I am new to this topic. When linear regression is applied, what feature does it take from the image? Color, shape, etc, or the whole image?
Thank you for the response!
Hi @niwlyer,
Ii will take all pixels of the image, either as RGB or Grayscale depending on your Image block configuration.
Hi @aurel ,
Appreciate the response. Do you have a post/article about the pre-processing steps for the Linear Regression (Keras) on the learning blocks. Learning the specific steps will help alot.
Thank you!
