Hi, i am trying to create a simple motion classification model but when i am trying to generate the features i am getting the error below:
Creating job… OK (ID: 1482704)
Scheduling job in cluster…
Job started
Creating windows from 116 files…
[ 2/58] Pre-caching files…
[58/58] Pre-caching files…
Pre-caching files OK
[ 1/116] Creating windows from files…
[116/116] Creating windows from files…
Created 9456 windows: jumping-jacks: 2624, push-ups: 1316, standing: 1412, stay-hydrated: 1870, walking: 2234
File “/home/create_features.py”, line 22, in
X_train = np.load(inFileX, mmap_mode=‘r’)
File “/usr/local/lib/python3.7/dist-packages/numpy/lib/npyio.py”, line 450, in load
return format.open_memmap(file, mode=mmap_mode)
File “/usr/local/lib/python3.7/dist-packages/numpy/lib/format.py”, line 869, in open_memmap
mode=mode, offset=offset)
File “/usr/local/lib/python3.7/dist-packages/numpy/core/memmap.py”, line 264, in new
mm = mmap.mmap(fid.fileno(), bytes, access=acc, offset=start)
ValueError: mmap length is greater than file size
Job failed (see above)
Thank you
