Hello, I am performing an image classifier of three features with each feature clearly labeled within the specified bounding box using MobileNetV2 SSD FPN-Lite 320x320 and getting an error in the “Object Detection” tab. Potentially, this is the same error that is from tensorflow https://github.com/tensorflow/models/blob/master/research/object_detection/core/box_list_ops.py
Creating job... OK (ID: 2205638)
Job started
Splitting data into training and validation sets...
Training model...
Training on 174 inputs, validating on 44 inputs
Building model and restoring weights for fine-tuning...
File "/home/train.py", line 333, in <module>
main_function()
File "/home/train.py", line 157, in main_function
model, override_mode, disable_per_channel_quantization = train_model(train_dataset, validation_dataset,
File "/home/train.py", line 72, in train_model
ei_tensorflow.object_detection.train(classes, 0.01, 100,
File "/app/./resources/libraries/ei_tensorflow/object_detection.py", line 73, in train
_ = detection_model.postprocess(prediction_dict, shapes)
File "/app/keras/.venv/lib/python3.8/site-packages/object_detection/meta_architectures/ssd_meta_arch.py", line 764, in postprocess
num_detections) = self._non_max_suppression_fn(
File "/app/keras/.venv/lib/python3.8/site-packages/object_detection/core/post_processing.py", line 1244, in batch_multiclass_non_max_suppression
batch_outputs = map_fn(
File "/app/keras/.venv/lib/python3.8/site-packages/object_detection/utils/shape_utils.py", line 239, in static_or_dynamic_map_fn
outputs = [fn(arg_tuple) for arg_tuple in arg_tuples]
File "/app/keras/.venv/lib/python3.8/site-packages/object_detection/utils/shape_utils.py", line 239, in <listcomp>
File "/app/keras/.venv/lib/python3.8/site-packages/object_detection/core/post_processing.py", line 1200, in _single_image_nms_fn
nmsed_boxlist, num_valid_nms_boxes = multiclass_non_max_suppression(
File "/app/keras/.venv/lib/python3.8/site-packages/object_detection/core/post_processing.py", line 630, in multiclass_non_max_suppression
selected_boxes = box_list_ops.concatenate(selected_boxes_list)
File "/app/keras/.venv/lib/python3.8/site-packages/object_detection/core/box_list_ops.py", line 634, in concatenate
raise ValueError('boxlists should have nonzero length')
ValueError: boxlists should have nonzero length
Job failed (see above)
