Currently, I download edge impulse Arduino Library and use continuous inference to classify sounds. However, sometimes after deployment of the device (Arduino Nano BLE Sense 33) it is required to update the model/ learning block. I am doing so using expert mode so that I can train the model locally without requiring Edge Impulse UI. Once I have trained the model I want to change the original downloaded library just so that the model is updated (Not the processing block) so that I can add more targets. Can someone suggest how would I be able to accomplish this. When I save the model in expert mode its in .pb file. How do I use it with Arduino Nano BLE Sense 33 to update the current library.
Thank you.
