I’m working on an audio classification project and used the data uploader on the web to upload my entire dataset. This ended up being a huge amount of data which was causing issues during the MFCC feature generation, the error message saying I should increase the window increase to reduce the number of windows. I played around with that setting until the error went away but I was wondering if there was a way to only use a subset of the uploaded data. I am not sure yet how much data is actually required and instead of uploading a bit, testing, then uploading more, etc it would be convenient if I could upload everything but choose only to use pieces.
I noticed there is a feature to enable/disable a sample. And I can use the filters and select multiple items features in the Data acquisition page to select several samples and disable them. But is there a way to select n samples randomly to disable them?
