I think a clever idea for Edge would be to implement some form of echo’d user-defined indexing, it doesn’t need to be complicated, just a way for users to define which message is being sent.
For instance, if I were to be sending data to the ingestion service every 30 seconds, but there is a bit of latency and the response time can be off a bit, all the while I might be requesting classification results, making other requests, etc.
Instead of having some iffy code searching for keywords in replies, such as “token,” or what have you, we can just parse out the returned index and pass that through some form of a switch so we can write code to handle specific replies when necessary, for instance, I want to request classification results upon reply of an ingestion post.
This is similar to how the software XPlane does it, when requesting different DREF values from the simulator aircraft, you can specify an index. This index is just echo’d back to us to we can determine successfully WHICH message we are getting a reply for, this way we can do many different operations without needing to wait for a reply in fear of it getting lost.
Maybe I’m just unfamiliar with HTTP and POSTING specs and there is a way to do with through the standard or through edge, but this would be very useful, and likely useful for others in the future.
If there is some reasoning behind why this isn’t a feature, or it couldn’t be either because its useless or I’m ignorant to this atm, please let me know.
