Is it possible to use the Edge Impulse API to download the WebAssembly build ?
I have looked at
and guessed that this command can be used but I don’t know what I need to specify as type.
I have looked at
I found it : type = wasm
so it must start with:
curl --request GET --url https://studio.edgeimpulse.com/v1/api/PROJECT_ID/deployment/download?type=wasm
It would be good to document this also.
It also would be good to mention explicitly the “PROJECT_ID” when consulting the project info dashboard.
I could figure out the project ID only thanks to below forum comment:
Hey @janvda, note that the options are rendered in the docs:
It would indeed be useful to show the project ID on e.g. the dashboard, will create a ticket!
This is now live:
Indeed, I overlooked it. I need some more sleep
Thanks also for adding the project ID !
