Question/Issue: I’m new to ML. Tried test put BLE 33 in 4 different position, 0, 45, 90, 180 degree to flat table surface. Each angle tried 20, so total 80 samples. Go through all the process to get a model. But the result is quite bad. From my side, it looks so obviously x,y,z value, but why the result is so bad? What I did wrong?
Found it (it was 135605 actually). I see that you are using a spectral features block but your data is constant, no specific frequency can be extracted from your samples.
I would suggest using a Raw or Flatten block instead.
I still see the spectral features in your project. Can you point me out to your project with the Flatten block? Also can you try with the Raw block as well?
