Upload file force same filename
A file is renamed in an random way. Correct?
Example:
If I upload test_2.9.csv using the dashboard I obtain test_2.9.csv.2hpla6of
This is something I like because I can link filename test_2.9.csv.2hpla6of with the file test_2.9.csv on my local machine. (note 2.9 is my speed label in m/s)
However using edge-impulse-uploader I obtain
test_2.2hpm7vod
in this case the .9.csv is thrown away (however this is not in case I use the dashboard, as explained above).
In case of test_2p9.csv I obtain test_2p9.2hpmmm37, only csv is throw away.
I can use xpy instead of x.y as in between solution and write a Python script where i replace p with . for the label.
Currently I use
edge-impulse-uploader --category {category} --label {label} --api-key {api_key} {path+file}
Is there an option for the edge-impulse-uploader to force the same filename test_2.9.csv becomes test_2.9.csv.+something random.
Joeri
In meantime I play with the EI API.
Using JSON gives:
‘x-file-name’: ‘test_2.9.csv’
Uploaded file to Edge Impulse 200 b’test_2.9.csv.2hre2o59.json’
I go for this approach.
Question: Is there a specific reason why there is some random value (in this case 2hre2o59) add at the end of the filename.
Hello @Joeri,
You can have a look at this thread: Getting floating points labels from file name
It is not completely answering your questions but it is somehow similar :wink:
Correct
test_2 .2hpm7vod
Yes, we take as the label what is before the first period, the rest we give it a random value to create unicity.
