What does this error mean about my audio data?
Hi, where did you get the files from, maybe itβs in the header?
you can send some files from not uploaded i will look
These files are recorded by the microphone i design. I can not upload cause the file is .wav format. How could i send you.
tiny.iatech@gmail.com
send, I will definitely look and if you can write the code, I think you are not creating the correct header
Thanks a lot. I have send some audio files to your email.
I looked, I think the matter is in the header of the wav file, it describes how the header should be, check it in your code, I took the recordings, opened them in the Audacity program and then made an export and everything loaded.
