I am trying to understand how the MFCC block works. If I understood correctly, after the Discrete Cosine Transformation, we have de cepstral coefficients. I have defined the number of coefficients in 13. After that, how does edge impulse obtain the characteistics to plot?
And, are these characteristics the input for the learning block, or learning block´s inputs are the spectrograms obtained after FFT?
Each column represents a window of time, which is determined by the “Normalization window size” parameter. Each row in that column is the cepstral coefficient for that window of time.
The entire 2D array of MFCCs are used as inputs to the learning block.
